  • 1994 - 1995 Specific Tech
MSD installation help
  • Thread starter Thread starter 99FiveOh
  • Start date Start date May 24, 2006
99FiveOh
2,051
20
99
J-Ville, FL
May 24, 2006
  • May 24, 2006
I have a 6AL and I'm pretty sure about most of the wires as far as where they go. My question is, what are the wires that trigger the MSD? Colors? Thanks a bunch!
BTW, I went on their site and they have general instructions, but nothing that pertains to the mustang wiring specifically.
FORCED2DV8
458
Grand Rapids MI
May 24, 2006
  • May 24, 2006
MSD make a specific wiring kit for our cars, that plugs right in to the box and into the coil, all you have to to do is hook up the power and Ground and switched 12 volts
99FiveOh
2,051
20
99
J-Ville, FL
May 24, 2006
  • May 24, 2006
I checked their site and all it says is "MSD to Ford TFI harness" I have a strong feeling this will only work with 93 and older Mustangs. I checked Summit also and didn't find any such harness.
I don't need this harness do I? I just want to know what color wires and where they are to splice into.
99FiveOh
2,051
20
99
J-Ville, FL
May 24, 2006
  • May 24, 2006
Ok, I found the harness on Summits website. So essentially what I do is run the existing coil wires into the MSD box, then the run wires from the box back to the coil. this is cake! no need to spend 25.00 on a harness, I can make splices look awsome!
Koniz
137
Geneseo, IL
May 25, 2006
  • May 25, 2006
It works on all TFI Ford Cars then the two bigger gauge wires go straight to the battery the harness is like 15 bucks i installed mine in like 15 min
3 eyed snake
24
louisville,ky
May 25, 2006
  • May 25, 2006
why splice? you spend $400 on a piece of good equipment and you dont want to spend $15 to $20 on doing it the right way.... it is just good insurance. never worry on a wire shorting out......
99FiveOh
2,051
20
99
J-Ville, FL
May 25, 2006
  • May 25, 2006
400$!! That's how much these MSD's are? I'm glad my brother is such a generous guy. He works at a salvage and just gave it to me. It's in perfect shape and he said it works.
I just went to the salvage yard today and cut off a coil plug from a EFI Ford. Now I'll just wire the plug to the MSD and plug it into my coil. Then, I'll attach space connectors to the other two wires from the MSD and plug them into my existing coil plug. No splicing and all the stock stuff is retained. No need to spend the 15.00.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
May 25, 2006
  • May 25, 2006
ya hookup is simple. i extended my wires and hid the box in the glove comparment.
i can scan the instructions if you still need them
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
M
Electrical Wiring issue
  • Maxnie21
  • Mar 23, 2025
Fox 5.0 Mustang Tech Mar 27, 2025
Maxnie21
M
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
