Mustang5l5's Progress Thread - Drivers side frame rail using donor piece
  • Sponsors(?)
95BlueStallion
Drop into my dm’s gurrrrrl
5,711
3,318
214
Cedar Rapids, Iowa
www.goodreads.com
I’ve personally come a long way since I did mine. I tacked mine, moving around and around to avoid warping. It turned out meh, but enough to trust it. Yours looks better. Wish I would have used gas, but glad to see yours coming out nice.
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
The gas made a huge difference. Was actually surprised how much so. Flux core seemed “hot” no matter how low I turned the power down. With gas, it seemed to penetrate easier with less burn through. Once I got the power and speed figured it, it was easy. Was worth the bottle purchase for sure.
I made notes on my settings. One setting to weld, and then a slightly weaker setting to fill the couple burned through spots where my panel gap was a little big.
I plan to grind the welds on the side just for appearance, but likely leave them in place underneath. Glad I started on the easy side.
Hate to say it, but it was actually fun. I’m probably going to end up filling holes now and definitely will be welding in my subframes myself.
Rdub6
Mustang Master
Dec 29, 2017
1,342
990
123
Long Island, NY
Looking good. I found it to be somewhat “addicting” myself. Definitely a fun skill to be learning!!
bird_dog0347
still married haven't seen testicles in years
5 Year Member
Jun 7, 2012
1,093
936
154
40
Little Elm, TX
The subframes were the only thing I really hated doing, but mainly just because of the angles and getting the welds right while laying on my back with the car not quite high enough.
  • Agree
Reactions: Mstng93SSP
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
Oh, i'm sure it won't be fun. I dispise anything to do while laying on my back under a car.
Still, I was all set to drop the car off at a local shop to have them done. Now, given my investment in the welder, I should actually use the thing. My confidence is going up the more I use it. I spend my evenings watching YouTube vids on MIG welding sheet metal and various techniques and angles. It's been a good skill to learn.
I would have loved to have kept going and finish the rail, but i need to grind the welds down a bit where the frame rail peices is going to patch into place for clearance. I may even add some small stitch welds to the backside of the tower and start working on filling holes.
I'm not going to fill EVERY hole. I'll just focus ont he ones on the towers where you will see the swiss-cheese look plain as day and some of the holes on the aprons. I plan on running a stock Airbox and battery in stock location otherwise i would have gone with the scott rod aprons. I'm not building a show car, just a clean driver. But...while i'm here
Reactions: Olivethefet
kendawg73
5 Year Member
Feb 5, 2014
454
114
64
47
Also picked up some of this stuff to spray inside when done
I've used a bunch of can's of that on mine... still have some in the basement, I still need to treat the rocker area's, will do that in a couple weeks, I'm going to spray it into any area I can't get too... I've done several coats on my frame rails already.
I do plan on recoating my frame rails every couple of years just for peace of mind... anything to stop rust....
Make sure you put masking tape over the bottom holes in your frame rail, and on the sides... so it don't spray/drip out...
Rdub6
Mustang Master
Dec 29, 2017
1,342
990
123
Long Island, NY
In hindsight, my inside welds came out better than my outside welds on my subframes. I went in headfirst, on my back, and had a good angle. For the outside ones I stayed completely out from under the car and struggled to get a good angle. If I were to do it again for the outsides, I’d go in feet first under the car, on my back, and have that same angle I had for the inside welds..... if that at all makes sense! Basically working right above your chest with the MIG gun.
darkfader
Mustang Master
Feb 16, 2017
243
319
83
44
Davis, WV
Awesome developments Mike. I had to go back more than 40 pages to get caught up, and your work looks amazing. When I saw your frame rails, I thought you bought another project fox. As clean as the black LX is, I'd have never guessed. Loving the engine work you did. I'm super motivated now to get mine finished up after seeing yours. Great work so far!
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
I didn't think it was that bad. The towers were solid and the outside of the rails looked perfect. Other than a small bubble on the pass side, I almost wasn't going to touch it. When I started cutting, it was all rotted out on the inside. Tons of sand in there, so I assume it held moisture.
I probably could have done a smaller patch and called it a day, but i wanted to cut it all out and do it right. Now that i'm nearly done with the pass side and my confidence is up, i have plans to take care of the driver's side in a different method.
Grinder wheels came in, so i need to finish cleaning up the weld and see if i can get it all welded up this weekend.
Reactions: General karthief
2Blue2
will be trying this sex one when I can find it
Mar 5, 2019
1,727
967
123
52
Oahu
Sure like your new welder
Its very nice
The patching is looking great, good clean work
This is such good use of shelter in place time
Right on
Admin Dude
Jan 4, 1985
28,537
10,648
224
Box behind Walmart
www.stangnet.com
Here's a geewiz question:
Where do you all generally buy your sheet metal from? It seems like Home Depot is probably not the way to go if doing these kinds of things regularly.
Rdub6
Mustang Master
Dec 29, 2017
1,342
990
123
Long Island, NY
A Tractor Supply opened near me recently. They had a pretty good selection of smaller pieces when they opened. Havnt been there in a while though.
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
McMaster-Carr.
Prob a few bucks more but their shipping is lightning fast.
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
Grinding wheels shows up (from McMaster). So I cleaned up the welds.
I did some small stitch welds on the backside that I didn’t grind. Figure that side can stay ugly. I am gonna fill those holes. I just want to get the rail done first. I’ll use a little filler later to smooth it out
Time to clamp my frame rail piece in place and make sure I like it.
Steel1
Mustang Master
Aug 18, 2017
973
423
93
50
Connecticut
Are you doing your welding with 110 volts ?
If so I would imagine the amp draw has to be in the 15 amp range, any breaker tripping issues or are you on dedicated circuit ?
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
I’m running it on a 15a circuit. No breaker tripping yet. I do have a 20a circuit I can use if needed a short distance away but hasn’t been necessary yet.
Not using max power. To weld the thickness I am, I’m using the machine at about 50% on the volt dial. The spot welds take a bit note power but no issues. It says max draw is 14.8amps. I’m probably in the 7-9amp range although if I can manage it I’ll try to measure.
I did wire the garage with 20a circuits and 220 power but my feeder run to my subpanel is just a huge PITA that I don’t want to deal with right now.
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
I did some work in the garage last night til 1AM. It’s rreally the only time I can get in there. Got the frame rail all patched in. I thought I took pics but guess not.
Wasn’t bad to stitch it in. The metal is thicker so I could use more power and not burn through. Initial pass was good, but then I made the rookie mistake of welding on top, so the bead is high. Nothing a grinder won’t fix.
I’m only going to grind the inner side in the engine bay for looks. On the outer rail I did fill some holes. I was tempted to start filling engine bay holes but I want to save my gas for the other side first.
I did spray the Eastwood frame coating. Very interesting, thick, stuff.
Just need to spot weld the top plate in, and fold the little tab back over and stitch weld it to the inner rail.
Almost done with first side.
Thread starter Similar threads Forum Replies Date
Mustang5L5 Mustang5L5's progress thread! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Mustang5L5 Mustang5L5 DIY MS3x Thread Digital Self-tuning Forum 104
insanestang ATTN: Mustang5L5 Fox 5.0 Mustang Tech 1
Red50Fox Constant vs. progressive coil springs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
LILCBRA LILCBRA's 87 GT convertible project (and it's lack of actual progress!!) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
Onesick99GT 99 Gt Progress Build 1996 - 2004 SN95 Mustang -General/Talk- 5
0 Progress thread - GT Auto to Manual Swap (and new seats!) SN95 4.6L Mustang Tech 21
Habu135 Progress Thread "12th Owner": My '93 Notchback Progress Thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 456
rademf64 Fox progress thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
G Progress Thread My new 5.0 engine bay progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
9 Progress build. 99 SVT 1996 - 2004 SN95 Mustang -General/Talk- 7
9 Anyone turbo their 3.8 sn95 Mustang ? [build progress] 1996 - 2004 SN95 Mustang -General/Talk- 5
TheFourEyedKid Progress Thread 1989 Daily Driver Build Up (probably slow progress) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
Q First Mustang GT...work in progress The Welcome Wagon 2
E Progress Thread Granny's Help and Progress Thread - 94 GT, I ain't skeered... 1994 - 1995 Specific Tech 25
BlakeusMaximus Progress Thread Smooth, slow progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 577
A Blew my motor, new MMR 750 build in progress 1996 - 2004 SN95 Mustang -General/Talk- 14
Sweetmarie66 66 Coupe Progress 1965 - 1973 Classic Mustangs -General/Talk- 8
Mstng93SSP 94 Cobra Progress Thread (formerly Help Me Decide Thread) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 168
2/75TH RANGER Finally ! Progress On The 302 ! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
Gunmonkey Thot: A Work In Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
FastDriver Progress Thread Reef Blue '93 GT Turbo Progress Thread - Houston we have a problem 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 233
darkfader Progress Thread Darkfader's 93 Gt Progress- Heads are here!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 259
Slobin3d 86 Mystery Mods Progress! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 182
K '88 Lx Vert Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
reeber Progress Thread 7 Year Build Back In Progress! 1996 - 2004 SN95 Mustang -General/Talk- 4
acoddo Progress Pics / Motor Teardown 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
ConnorM37 2000 Gt Engine Swap- In Progress 1996 - 2004 SN95 Mustang -General/Talk- 12
DrakeRobinson68 Hello From Ca With A '68 In Progress 1965 - 1973 Classic Mustangs -General/Talk- 8
acoddo Progress Pictures 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
RangerJoe Nos Mini Progressive Review 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
F Progress!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
RaggedGT Progress Thread The Ragged Gt Thread-little To No Progress Made-I May set it on Fire 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 164
rd Back At It, But Slow Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
Jaystang73 Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
87_notch_402 Fox 87 Notch Progresss 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 73
falconater Fairmont Progress? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
John Dirks Jr More Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
J.dement Neglected 2000 3.8l Restoration Progress (12.2.16) SN95 V6 Mustang Tech 0
S Progress Thread 2001 Gt Progress Thread - Stock Video 1996 - 2004 SN95 Mustang -General/Talk- 1
v8stang289 V8stang289's 86 Gt That's Taking Way Too Long -progress Thread - 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 29
91BlckGT 91blckgt's "about *&$# Time" Progress Thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 84
Crazedstang Progress Thread Slow Progress On My "illegally Abused" 1988 Gt 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 37
MrFoxNutCase Finally Some Progress On Project Smoke Grey Int. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
B Iac / Overheating Woes - Progress And Questions SN95 4.6L Mustang Tech 2
90BlueGTStang Paint Progress 90 Gt 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
2000xp8 SOLD Saleen Foxbody Progressive Rate Lowering Springs Suspension Parts 1
awilli93coupe Mini Tub In Progress!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 50
Chuckman Progress Thread Street/strip 427w In A Gt Hatch- Slow Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 261
MY 85 GT Little Progress Today. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
