Mustang5l5's Progress Thread - Drivers side frame rail using donor piece
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
A little more work today.
Ground the welds down on this face. I left the rear weld mostly intact. Nobody will see it and I feel more comfortable leaving most of it high. The folded over tab covers most of it anyway
On the underside, I ground the front weld where the k member needs to sit. I left the rear weld intact. It looks high and cold because I made the mistake of welding over it and all it did was build up higher.
I didn’t plug weld the top plate yet. I need to drill my holes and adjust the tabs to sit nice and tight. Once I get that all set I can weld this in and spray some frame paint inside and call it a day.
I did fill the holes on this side. I wanted to practice filling plus with the coil overs I needed to move the brake and fuel line clip to a new spot. . I left the bottom seam weld intact with no grinding.
Yes, this side is uglier. I did a couple stitches on the tower from the backside
  • Sponsors(?)
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
Looking ahead..the other side. I still have some rusty metal to cut out. I’m not confident the Scott Rod patch is going to cover enough.
I’m going to do something else for this side. I need to get that booster out first.
Rdub6
Mustang Master
Dec 29, 2017
1,342
990
123
Long Island, NY
So that booster is coming out, and going in the parts bin!!!
Towers looking good. Making quick work of it now that your getting going!!
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
Sweet! What Master is on that thing? Will it work right with the Brembo fronts and 43mm or 38mm rears?
1 1/8” bore. I know guys are using it with hydroboost and the ATS/43 and claiming pedal feel is close to stock. The max motorsports kit includes a new pedal to corrrct the ratio so not sure how that will affect things.
Reason for changing it is because it’s easy with the engine out to plumb it up and install it, and I want some unique touches.
bird_dog0347
still married haven't seen testicles in years
5 Year Member
Jun 7, 2012
1,093
936
154
40
Little Elm, TX
AAAANNNNNDDDDDD it lays the foundation for a Coyote swap later... #amiright?
2Blue2
will be trying this sex one when I can find it
Mar 5, 2019
1,727
967
123
52
Oahu
liking the progressive shots
dang you cut a big ole hole in that car...
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
From the outside, all you saw was a little bubble. I prob could have just done a small plate, but I wanted to cut all the rust out and get fresh metal in there.
Other side will be a little bit bigger hole...
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
Added the Max motorsports sway bar reinforcement plate. Prob not necessary for my driving style...but they were cheap, and I’m here. Might as well.
Didn’t do other side yet til I finish that rail
I’m also wirewheeling and cleaning the metal as I go and spraying some primer. I’ll do a bulk sanding later on before I paint the bay.
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
In my quest to track down supplies that don't take 4 weeks to show up, I needed some flap disks.
If you use the coupon code "FREEMIX" at checkout, the disks are free and you just pay $10 for shipping. I thought that was pretty good for basically $1 a flapdisk.
No idea how many weeks it will take though.
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
Pass side done.
Time to start drivers side. I think I’ll be taking a different approach here. I bought @Gravydog driver new edge rail.
Quick cleanup.
Next step is pull my booster. I need access to inspect the rail. I think the main rail metal is too thin to weld to. Just not sure I want to take the chance but I want to drill ou the inner rear apron and inspect first. I have two plans.
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,029
224
Massachusetts
WOrked a bit on stripping the donor rail down. Pulled off the front and rear aprons (what was left of them) the top cap and the rear firewall support. I may weld up some of the holes while I am here.
There is a small brace inside the firewall support that holds the rail. Interestingly enough, it has a part number on it
Need to get the booster out now. I need to remove the rear apron/top cap to see the extent of thin metal back there. Then I’ll know my plan
88LX5.Oh
5 Year Member
Dec 30, 2011
1,445
207
84
Arkansas
I haven't logged on to this forum in probably 7 years. It's wild to see some of the same usernames still around on here. Anyways I'm just glad I'm not the only one here with an unfinished car after all these years lmao
CarMichael Angelo
clearly, I’ve got something going on in that hole
SN Certified Technician
13,621
234
62
Birmingham, al
m.imdb.com
I cant see how as.........What's the right word......"thorough"? As you are, that you are not dealing with the 50 bagillion holes in the strut towers that are in front of you.
Right under your nose.
Thread starter Similar threads Forum Replies Date
Mustang5L5 Mustang5L5's progress thread! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Mustang5L5 Mustang5L5 DIY MS3x Thread Digital Self-tuning Forum 104
insanestang ATTN: Mustang5L5 Fox 5.0 Mustang Tech 1
Red50Fox Constant vs. progressive coil springs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
LILCBRA LILCBRA's 87 GT convertible project (and it's lack of actual progress!!) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
Onesick99GT 99 Gt Progress Build 1996 - 2004 SN95 Mustang -General/Talk- 5
0 Progress thread - GT Auto to Manual Swap (and new seats!) SN95 4.6L Mustang Tech 21
Habu135 Progress Thread "12th Owner": My '93 Notchback Progress Thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 456
rademf64 Fox progress thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
G Progress Thread My new 5.0 engine bay progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
9 Progress build. 99 SVT 1996 - 2004 SN95 Mustang -General/Talk- 7
9 Anyone turbo their 3.8 sn95 Mustang ? [build progress] 1996 - 2004 SN95 Mustang -General/Talk- 5
TheFourEyedKid Progress Thread 1989 Daily Driver Build Up (probably slow progress) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
Q First Mustang GT...work in progress The Welcome Wagon 2
E Progress Thread Granny's Help and Progress Thread - 94 GT, I ain't skeered... 1994 - 1995 Specific Tech 25
BlakeusMaximus Progress Thread Smooth, slow progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 577
A Blew my motor, new MMR 750 build in progress 1996 - 2004 SN95 Mustang -General/Talk- 14
Sweetmarie66 66 Coupe Progress 1965 - 1973 Classic Mustangs -General/Talk- 8
Mstng93SSP 94 Cobra Progress Thread (formerly Help Me Decide Thread) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 168
2/75TH RANGER Finally ! Progress On The 302 ! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
Gunmonkey Thot: A Work In Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
FastDriver Progress Thread Reef Blue '93 GT Turbo Progress Thread - Houston we have a problem 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 233
darkfader Progress Thread Darkfader's 93 Gt Progress- Heads are here!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 259
Slobin3d 86 Mystery Mods Progress! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 182
K '88 Lx Vert Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
reeber Progress Thread 7 Year Build Back In Progress! 1996 - 2004 SN95 Mustang -General/Talk- 4
acoddo Progress Pics / Motor Teardown 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
ConnorM37 2000 Gt Engine Swap- In Progress 1996 - 2004 SN95 Mustang -General/Talk- 12
DrakeRobinson68 Hello From Ca With A '68 In Progress 1965 - 1973 Classic Mustangs -General/Talk- 8
acoddo Progress Pictures 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
RangerJoe Nos Mini Progressive Review 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
F Progress!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
RaggedGT Progress Thread The Ragged Gt Thread-little To No Progress Made-I May set it on Fire 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 164
rd Back At It, But Slow Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
Jaystang73 Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
87_notch_402 Fox 87 Notch Progresss 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 73
falconater Fairmont Progress? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
John Dirks Jr More Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
J.dement Neglected 2000 3.8l Restoration Progress (12.2.16) SN95 V6 Mustang Tech 0
S Progress Thread 2001 Gt Progress Thread - Stock Video 1996 - 2004 SN95 Mustang -General/Talk- 1
v8stang289 V8stang289's 86 Gt That's Taking Way Too Long -progress Thread - 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 29
91BlckGT 91blckgt's "about *&$# Time" Progress Thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 84
Crazedstang Progress Thread Slow Progress On My "illegally Abused" 1988 Gt 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 37
MrFoxNutCase Finally Some Progress On Project Smoke Grey Int. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
B Iac / Overheating Woes - Progress And Questions SN95 4.6L Mustang Tech 2
90BlueGTStang Paint Progress 90 Gt 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
2000xp8 SOLD Saleen Foxbody Progressive Rate Lowering Springs Suspension Parts 1
awilli93coupe Mini Tub In Progress!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 50
Chuckman Progress Thread Street/strip 427w In A Gt Hatch- Slow Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 261
MY 85 GT Little Progress Today. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
