Mustang5l5's Progress Thread - Drivers side frame rail using donor piece
  • Sponsors(?)
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
32,867
9,030
224
Massachusetts
I cant see how as.........What's the right word......"thorough"? As you are, that you are not dealing with the 50 bagillion holes in the strut towers that are in front of you.
Right under your nose.
They will be dealt with. I just want to get the other frame rail done first. Then I can chip away at the holes.
Last thing I want to do is burn through all my gas doing the little holes. However, doubt that will happen. I used 200psi to do the pass side rail, and have 1500psi left in the bottle.
Trust me... this is going away.
02 281 GT
Agreed...My wife has great Boobs
2,231
1,355
174
Cabot, AR
Booster out. The come out a lot easier than going in.
Anyway, time to get at it. Goal seems simple. Put the silver piece where the hole is. Easy enough
Is the portion of the tower on the donor piece going to give you more room for the booster/hydroboost?
I conserved gas when I was welding by shutting it off any time I stopped welding for more than a minute. I'd hang my helmet or gloves on the bottle to ensure I didn't forget to turn it back on. I was able to weld in the toe board patches, front torque boxes, passenger rocker repair, and the full floor pan without having to get the bottle refilled.
Mustang5L5
Mod Dude
Feb 18, 2001
32,867
9,030
224
Massachusetts
Kudos to Mustang Parts Specialties
I sourced my hydroboost setup from then. Upon inspection, I found a crack in the receiver where the pedal rod joins the booster. If this fails, the rod comes out.
Upon notifying them, they just sent out a new unit...MC and all. Didn’t even want me to send back the old one. Zero hassle
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,357
2,824
234
74
Dublin GA
lowendmac.com
I am. Dash needs to come out to replace the evap core, so I’ll install then.
I am headed in the same direction: removing the dash to get to the evaporator core. I have already had the dash out once to replace the heater core and I am avoiding it. Soon the Georgia summer heat will get to me and I''ll take a week off to do the job sloooowly…. :(
Reactions: General karthief
HotFox
964
548
134
40
SE Michigan
You has a welder! JK...good deal!
kendawg73
5 Year Member
Feb 5, 2014
454
114
64
47
I’ve put it off for years due to hassle, but at this point it’s now or never.
I really need ac in this thing
I took all mine out last year to do the core and Evap... just have to put it back in still... I'm sure you have a shop Manuel, but in case you didn't, the YouTube and interwebs have the wrong info on how to replace the evap... people are trying to use the sealer and epoxy ect. to put/hold the plastic flap/lid on the A/C box you have to cut to remove the Evap..
You are suppose to drill 2 holes and get spring clamps and attach to the spots they put in the housing just for this after it's cut open.. then you just use sealer to seal the crack.. but the spring clamps hold the lid down.. all the videos I seen people are loading it up with epoxy ect to hold the lid down/in place.
BlakeusMaximus
Still got to try a little lube on my speedo head
Jul 12, 2017
1,969
1,111
153
Getting my A/C working is on my short list. Do you know where they sell the conversion kits, or if there is such a thing?
Olivethefet
Slap me as well as point and laugh
May 17, 2018
1,589
1,010
123
39
Enterprise AL
When I was researching new AC systems all I found is that everything was the same if you used R12 or R134. It's all about the oil. If you are retrofitting an old system you have to clean the old oil out. If a new system the only difference is the oil you use. The R12 oil is not compatible with the 134 oil. Hope that helps @BlakeusMaximus
JD08
I love your drawers
Apr 22, 2017
238
143
53
54
The fittings are sized differently. That might not be an issue if you do all your own work and have the right manifold gauges though.
CarMichael Angelo
clearly, I’ve got something going on in that hole
13,621
234
62
Birmingham, al
m.imdb.com
Ahh the cycles of Fox Mustang ownership...
21-40: Remove every belt driven accessory on the front of the engine not required for it to run, put on underdrive pulley system.
41-60: Put it all back.
Thread starter Similar threads Forum Replies Date
Mustang5L5 Mustang5L5's progress thread! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Mustang5L5 Mustang5L5 DIY MS3x Thread Digital Self-tuning Forum 104
insanestang ATTN: Mustang5L5 Fox 5.0 Mustang Tech 1
Red50Fox Constant vs. progressive coil springs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
LILCBRA LILCBRA's 87 GT convertible project (and it's lack of actual progress!!) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
Onesick99GT 99 Gt Progress Build 1996 - 2004 SN95 Mustang -General/Talk- 5
0 Progress thread - GT Auto to Manual Swap (and new seats!) SN95 4.6L Mustang Tech 21
Habu135 Progress Thread "12th Owner": My '93 Notchback Progress Thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 456
rademf64 Fox progress thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
G Progress Thread My new 5.0 engine bay progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
9 Progress build. 99 SVT 1996 - 2004 SN95 Mustang -General/Talk- 7
9 Anyone turbo their 3.8 sn95 Mustang ? [build progress] 1996 - 2004 SN95 Mustang -General/Talk- 5
TheFourEyedKid Progress Thread 1989 Daily Driver Build Up (probably slow progress) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
Q First Mustang GT...work in progress The Welcome Wagon 2
E Progress Thread Granny's Help and Progress Thread - 94 GT, I ain't skeered... 1994 - 1995 Specific Tech 25
BlakeusMaximus Progress Thread Smooth, slow progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 577
A Blew my motor, new MMR 750 build in progress 1996 - 2004 SN95 Mustang -General/Talk- 14
Sweetmarie66 66 Coupe Progress 1965 - 1973 Classic Mustangs -General/Talk- 8
Mstng93SSP 94 Cobra Progress Thread (formerly Help Me Decide Thread) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 168
2/75TH RANGER Finally ! Progress On The 302 ! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
Gunmonkey Thot: A Work In Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
FastDriver Progress Thread Reef Blue '93 GT Turbo Progress Thread - Houston we have a problem 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 233
darkfader Progress Thread Darkfader's 93 Gt Progress- Heads are here!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 259
Slobin3d 86 Mystery Mods Progress! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 182
K '88 Lx Vert Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
reeber Progress Thread 7 Year Build Back In Progress! 1996 - 2004 SN95 Mustang -General/Talk- 4
acoddo Progress Pics / Motor Teardown 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
ConnorM37 2000 Gt Engine Swap- In Progress 1996 - 2004 SN95 Mustang -General/Talk- 12
DrakeRobinson68 Hello From Ca With A '68 In Progress 1965 - 1973 Classic Mustangs -General/Talk- 8
acoddo Progress Pictures 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
RangerJoe Nos Mini Progressive Review 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
F Progress!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
RaggedGT Progress Thread The Ragged Gt Thread-little To No Progress Made-I May set it on Fire 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 164
rd Back At It, But Slow Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
Jaystang73 Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
87_notch_402 Fox 87 Notch Progresss 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 73
falconater Fairmont Progress? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
John Dirks Jr More Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
J.dement Neglected 2000 3.8l Restoration Progress (12.2.16) SN95 V6 Mustang Tech 0
S Progress Thread 2001 Gt Progress Thread - Stock Video 1996 - 2004 SN95 Mustang -General/Talk- 1
v8stang289 V8stang289's 86 Gt That's Taking Way Too Long -progress Thread - 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 29
91BlckGT 91blckgt's "about *&$# Time" Progress Thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 84
Crazedstang Progress Thread Slow Progress On My "illegally Abused" 1988 Gt 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 37
MrFoxNutCase Finally Some Progress On Project Smoke Grey Int. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
B Iac / Overheating Woes - Progress And Questions SN95 4.6L Mustang Tech 2
90BlueGTStang Paint Progress 90 Gt 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
2000xp8 SOLD Saleen Foxbody Progressive Rate Lowering Springs Suspension Parts 1
awilli93coupe Mini Tub In Progress!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 50
Chuckman Progress Thread Street/strip 427w In A Gt Hatch- Slow Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 261
MY 85 GT Little Progress Today. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
