Mustang5l5's Progress Thread - drivetrain done!!
Steel1
Mustang Master
Aug 18, 2017
807
332
93
50
Connecticut
I got the stock valve covers to fit on my RHS heads with the same Comp gold rockers by removing the baffles and grinding down
the mounting bosses.
Looks good !
  • Sponsors(?)
TOOLOW91
6,809
234
S.I.NY
Ok valve covers here.
And they don’t fit. They are def taller but the baffle hits.
That’s with the baffle plate removed.
Looks like one of the bosses is hitting the poly lock. What to do here? @TOOLOW91 did you do anything to get yours to fit?
I wish I had an answer .
You could try and trim in there but both sets of TW heads with the same Harland sharp rockers all cleared the valve covers On mine with the blue felpro gaskets. I think they actually sit flush even without a gasket too
Reactions: Mustang5L5
Mustang5L5
A little massaging and it went right in
Mod Dude
Feb 18, 2001
32,255
8,450
224
Massachusetts
Pretty sure grinding those bosses down will do the trick. Sucks to lose the baffle but I can deAl with that
Steel1
Mustang Master
Aug 18, 2017
807
332
93
50
Connecticut
Did you do anything to address oil consumption?
I used these rubber baffles and pushed them into the oil fill tube, I measured the i.d. and
got a size that fit tight. In hind sight I probably don't need them, I think I had to trim them a bit iirc.
I customized my valve covers so I have a oil fill tube on each one , I use them to vent into a catch can.
I have no oil consumption issues with this engine.
Mustang5L5
Mod Dude
Feb 18, 2001
32,255
8,450
224
Massachusetts
Nice. I'll likely do the same.
I'll take the grinder to the driver's side cover and remove those bosses. I'll take some playdoh to check clearances after. Since the covers are the same casting, if it works on one side, it should work on the other.
No where the hell is my grinder?
TOOLOW91
6,809
234
S.I.NY
My driver side one is a efi cover that we welded a bung right in the front corner facing the ac compressor and it has had no baffle ever . Never an issue . Passenger side is a carb one with a fitting welded in the push in breather hole . I kept that baffle . No issue
General karthief
Mod Dude
Aug 25, 2016
14,860
4,690
193
polk county florida
that grinder is right over there.
Admin Dude
Jan 4, 1985
27,938
10,208
224
Box behind Walmart
www.stangnet.com
I have a small oil separator installed there but your solution will likely work fine until/unless you boost.
Of the small 'Husky' oil separators that you see at Home Depot, I might get 1/3 between oil changes. I just didn't want to feed that oil back to the intake. I didn't care too awful much about the little bit of loss.
90sickfox
I didn't really have an issue with the stink...
SN Certified Technician
Mar 2, 2015
4,792
4,007
183
42
Just a thought. I've seen then on cars running factory covers and roller rockers. I'm not a fan of the gaskets and prefer Felpro blue neoprene gaskets. The upper intake may need a spacer too to clear the valve covers.
Mustang5L5
Mod Dude
Feb 18, 2001
32,255
8,450
224
Massachusetts
I bought aboit those too, but didn’t like the gaskets on those and the fact I’d need to put a large spacer on the intake. I’m running a 3/8” spacer now and that’s as much as I can go before I am rubbing on the hood.
If I am gonna run a spacer that big anyway, I’d prob sell these and just go with the Proform/Ford racing slant covers.
Got my grinder ready. Can’t tackle it til Monday. I’m confident these will work when I remove one problem boss
Admin Dude
Jan 4, 1985
27,938
10,208
224
Box behind Walmart
www.stangnet.com
I also have Scorpion under the stock valve covers.
Raising the intake for me is an option but a huge PITA option due to the location of the blower snout etc. It does all fit and work well.
Mustang5L5
Mod Dude
Feb 18, 2001
32,255
8,450
224
Massachusetts
Well, consider this....I currently have one stock OEM valve cover bolted down on the drivers side.
So I know once I grind down the offending boss, these will fit fine.
Reactions: General karthief
bird_dog0347
I really enjoyed seeing your rear end up close
5 Year Member
Jun 7, 2012
1,002
854
154
39
Little Elm, TX
Thanks to you and all your research, my wallet is about $500ish lighter. I ordered the Brembo brackets from LowRanger on SVT forum as well as front ATS Brembo calipers and rear Taurus calipers from Rock Auto. Hopefully they fit my front wheels, but I think they will since I have 18's and the front already has a decently large spacer due to the offset. This will hopefully fix my pedal issue as well, since I have the GT Master Cylinder with the Cobra brakes. Now I need to figure out pads and how I want to paint them all.
Mustang5L5
Mod Dude
Feb 18, 2001
32,255
8,450
224
Massachusetts
Let me know how it turns out. I plan on installing them as well but have a few things to do first obviously. One of these days soon I plan on painting up the calipers
bird_dog0347
5 Year Member
Jun 7, 2012
1,002
854
154
39
Little Elm, TX
Will do, I assume it will be a few weeks to months though... I think the spacers are 3-4 weeks out from being ready to ship so I'll have to wait at least till then. And I still need to decide on pads, paint the calipers, and order some MM SS front brake hoses to match what I put on the rear when I did the IRS. That and I just got the heater core redone and have the car back on the road so I'll drive it for a bit as is.
Where did you order your brembo stickers from? Any recomendations on paint? Rattle can or brush on?
