Mustang5l5's Progress Thread - Fuel rails
  • Sponsors(?)
Mustang5L5
This is a big reason why I pulled it out
Mod Dude
Feb 18, 2001
31,750
7,946
224
Massachusetts
So just a different piston size? I forget, what is the size of the cobra rear piston?
38mm rear piston on the SN95's.
This one is 43mm. Would give you a little more rear clamping force, which normally you don't want except in the case of sticking Brembo brakes up front and finding your front bias is a little too much.
Mustang5L5
Mod Dude
Feb 18, 2001
31,750
7,946
224
Massachusetts
Interesting. So it bolts right up? What pads the Taurus or Sn95?
Sn95 pads.
The only part you need to change out is the actual caliper that has the piston. Everything else stays the same.
Cardone 18-4537, and 18-4536
This is all you need to swap. Everything else is SN95 mustang (rotors, brackets, pads, line, e-brake, caliper bracket)
Mustang5L5
Mod Dude
Feb 18, 2001
31,750
7,946
224
Massachusetts
Interesting...so they use this in a true 4 door passenger car and not the mustang of those years.
On a 10.1” non-vented rotor as well.
The 93-00 Lincoln Continental got the rear 43mm calipers as well
Selecting an MC to use with these and the ATS Brembos is tricky. I’ve been doing some math and ideal MC is in between the 93 cobra 1” and the 94/95 GT 1 1/16”.
The 1” is a bit on the soft pedal side, and the 1 1/16” might be only slightly firm. Looks like 1 1/16” might be the one to try
Mustang5L5
Mod Dude
Feb 18, 2001
31,750
7,946
224
Massachusetts
Some more Caliper pics. Fits perfectly
I measure right around 41-42mm but can’t really fully measure the piston OD. Online spec claims 42.8mm
Mustang5L5
Mod Dude
Feb 18, 2001
31,750
7,946
224
Massachusetts
Back to the motor. Finalized my pushrod meaurement. Ended up at 7.800”. Most people say TFS heads are 6.700-6.750”, but I felt I got a tighter pattern and closer to the center of valve with 6.800”.
With that done...I bolted on the intake
Took the opportunity to dress it up a bit with ARP hardware and new Motorcraft sensors of course.
Now, it’s all the little odds and ends. Need a new PCV grommet, the nipple for the egr coolant line, misc other hardware. Plus I need to “restore” everything else, like the heater tube and fuel rails.
Oil pan stud kit comes Friday. That’s next.
This motor really looks nice. Can’t wait to get it in the car...and hopefully it’s oil leak free!!
CarMichael Angelo
Nobody appreciates me..I'm gonna cut my ear off
SN Certified Technician
12,799
234
62
Birmingham, al
m.imdb.com
It's normal for me to not pay attention to a stock 5.0 build, but your attention to detail, and obsessive level of perfection- ( numbering the ports on the head, when an arrow pointing to the front, or the letters p&d would've made that an automatic thing) , make it so I just have to follow this. You make a build/progress thread what it's supposed to be-- A place to learn something, not just a bunch of pics with a "look what I did" caption at the bottom.
Reactions: Mustang5L5
Steel1
Mustang Master
Aug 18, 2017
722
284
93
50
Connecticut
Now....because this question always has to be asked lol...
How did you seal the end rails ?
From pics looks like a nice bead of black rtv.
Mustang5L5
Mod Dude
Feb 18, 2001
31,750
7,946
224
Massachusetts
Only in the corners. I’ve never done the full RTV bead method and have had great luck like that
I’m using the newer explorer intake gasket set that comes with the blue molded end rail gaskets. I just did four dabs in the corners.
The MS 95952 gasket set. The head ports line up perfectly with it and I had my explorer intake ported to it. The transitions line up perfectly if you peer down the intake runners
Reactions: pats91
Admin Dude
Jan 4, 1985
27,297
9,703
224
Box behind Walmart
www.stangnet.com
No, I bought the standard flow. I read up on all the "watch-outs" with the HV and decided I didn't need it
Thank the Mustang Gods.
HV pumps on a street motor are another of those interwebz overrated unicorns belly-button mods.
I also vaguely recall a set of oil drain plugs that have to be removed from the top of the [something] on [some] heads and not others and blah blah what a pain the ass we shoulda just kept the OEM pump and called it quits godammit what a waste of time and money I hate the interwebz hammer time.....
Reactions: General karthief
Mustang5L5
Mod Dude
Feb 18, 2001
31,750
7,946
224
Massachusetts
Now my big oops. Needed 6.800” pushrods.... I ordered 7.800
My new Ford racing dipstick doesn’t fit the block hole. Need to investigate this.
Slowly getting there
Reactions: Hoytster
