Mustang5l5's Progress Thread - misc stuff
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,359
9,658
224
Massachusetts
Ok, spent about another hour on the car smoothing out the filler holes and taking some light surface rust areas down to bare metal. Starting to spread out and prep for painting. I do want to test fit the MM k member Before paint just in case.
starting to gather supplies. Painting is not my forte. I am more a mechanical guy, but I guess I know how to research and learn.
body Filler. I need some. Not much. I don’t want to drop $100 on a fancy filler to use a tiny portion of it. What’s good for light coverage in an engine bay?
paint. I don’t have the right supplies, or want to drop $400+ on a used Sata paint gun. I don’t want a rattlecan job either, but after checking out a the Eastwood 2k paint setup, I might go that route. It’s a rattle can, but has an internall bkadder with hardener. Once you mix, you have 48 hours. I’m thinking of going this route. It’s a black engine bay, in which most stuff is going back in anyway.
but here’s my thought.
sand, flap disk, wire wheel etc on the bay to get rid of all surface oxidation. Lightly smooth out the holes. 2k epoxy primer, light sand?? (Or not?) then clean and do 2k black (unsure if I should do black or underhood black) , clean and 2 clear. (Prob gloss instead of matte)
only doing the inner bay. Outer fender area and radiator support lower area will be a mix of POR-5 and Eastwood frame paint. More protection, vs looks since it will all get covered or face the ground.
fall is approaching here in MA. I have a window of low humidity and 60-70degree temps. after oct it drops fast, so I can’t wait too long to paint. I can warm it up in the garage but I need to open doors for ventilation.
I think that’s my plan. Any changes? @Davedacarpainter
  • Sponsors(?)
Davedacarpainter
I think I've messed my pants
SN Certified Technician
Nov 28, 2015
11,449
11,036
193
58
Discordia
I’ve never been a big fan of epoxy primers myself mike. They’re good at providing a barrier and binding coat over bare metal, but for filling, they are more difficult to sand smooth.
So, either use a coat of epoxy for the bare metal then primer like normal, or use an etch primer and coat with a regular 2k urethane primer.Then, yes, sand it down with 400-600 grit.
I’ve recently got back into using acid etch wipes at work prior to primer. This is what i use on bare metal now before primer. It’s similar to what we used to use 40 years ago. What’s old is new again I guess.
As for filling the welded holes. Any type of glaze should cover them nicely. You can get a glaze in smaller quantities, like a quart at the largest.
Mustang5L5
Mod Dude
Feb 18, 2001
33,359
9,658
224
Massachusetts
Geez. Those wipes aren't cheap.
$125ish for 25 wipes. I'll need like...2?
Thanks Dave. I'm rounding up supplies. Still have some metal prep to do and not trying to rush.
Davedacarpainter
Nov 28, 2015
11,449
11,036
193
58
Discordia
Yeah, I don’t really know the price, sorry Mike.
You can use a rattle can of etch primer. Let it dry for twenty minutes or so, scuff and spray high build primer over it.
91TwighlightGT
1,035
283
124
37
Missouri
Visit site
I agree that Epoxy primer is hard to work with, but part of that is because it is very hard. I like the idea of epoxy primer in your strut tower repair areas as it will provide the most protection IMO.
for the rest of the bay, though, it’s not necessary and will just be difficult and messy.
I see no reason to go with any kind of expensive equipment for this project. In fact, just harbor freight guns would do the trick. Just make sure the tip sizes are correct for the paint you are spraying. if you are using just a single gun you will need different tips for the primer (larger tip) and base (smaller tip)
I would also spring for the filter that goes between your gun and air hose, they aren’t that expensive and moisture in the line will cause fisheyes which is frustrating as hell.
if it is just the engine bay in black, consider a single stage paint. You don’t need a lot of Jc protection under the hood, and it is easier to repair if it gets chipped or scratched.
Reactions: Mustang5L5
Mustang5L5
Mod Dude
Feb 18, 2001
33,359
9,658
224
Massachusetts
WHat about the epoxy primer in the outer fender/tower area? I don't need to sand there as i'm just looking for protection. Should I use that on top of the bare metal?
Basically anything out of sight, like the outer fender aprons, bottom frame rails, radiator support, trans tunnel, I just want to protect. The "good" paint job will be the frame rails up only in the bay area.
91TwighlightGT
1,035
283
124
37
Missouri
Visit site
The only reason I would use self etch is for adhesion. It provides minimal rust protection, and is absolutely meant to be top coated. If you leave a piece of sheet metal outside with only self etch, it will eventually rust.
Epoxy is hard, durable, and waterproof. The hardness makes it difficult to work with which is why you typically wouldn’t try to use it directly before topcoating because high build is easier to spray and sand.
With that said, for areas that won’t be getting worked it is an excellent choice for durability and rust prevention. Personally I would still topcoat it because you are adding an extra layer of protection, and because epoxy is not UV resistant like a urethane.
So, to recap, yes I would spray epoxy on the areas where you plan to do minimal body work and are concerned about rust.
Reactions: JustinL
Mustang5L5
Mod Dude
Feb 18, 2001
33,359
9,658
224
Massachusetts
Roger, got it.
I'll just pick up some filler, self-etch, some urethane primer, and my top coat.
In the meantime, prep prep prep.
91TwighlightGT
1,035
283
124
37
Missouri
Visit site
As an aside, when you go to your paint supplier they will give you the tech sheets on the products with all of the mixing information, flash off times, etc.
Make sure you buy solvent for cleaning your gun(s). If you let epoxy dry in your gun you might as well just throw it out. I can’t stress enough how important it is to clean your guns as soon as you are done spraying.
Also make sure you get some filters (they are one use paper filters for pouring) and measuring cups. If you clean your cups you can reuse them, but if you let stuff dry in them then that stuff flakes off when you pour the next time.
Water filter...
There are other kinds available, we actually used a cheaper one but I kind of like this design.
Reactions: JustinL
Mustang5L5
Mod Dude
Feb 18, 2001
33,359
9,658
224
Massachusetts
Got some net material today. Ordered from two vendors. They sell the netting by the pound. Ordered 1 pound from each vendor. Same price. They both came today. Quite a difference in what goes for a lb these days.
left side matches pretty well. Time to dye it black, trim it, and sew it into the pattern.
Reactions: hoopty5.0
Mustang5L5
Mod Dude
Feb 18, 2001
33,359
9,658
224
Massachusetts
I noticed that too. I was wondering though. Does it look like fluid as been in it? Unless that is just from sitting on a shelf?
Doesn't look any different than the one I have. Looks like typical solder and surface oxidation. I may have overpaid for mine, so i'm watching this one to see what it goes for to know if i did, or I paid market value.
I took some shots of mine compared to the standard Parts store aluminum replacement. Night and day difference
FortySix&2
42
Madison Wi
Those comparison shots make me want to bid on it. I have owned my car since 98 and have never changed the core. No idea if it was done previously.
Admin Dude
Jan 4, 1985
28,765
10,720
224
Box behind Walmart
www.stangnet.com
If you don't smell anti-freeze when the heater/defrost is on, I personally wouldn't mess with it unless I had some other reason to take it all apart.
Admin Dude
Jan 4, 1985
28,765
10,720
224
Box behind Walmart
www.stangnet.com
Just a friendly reminder:
There is supposed to be an orifice installed on the inlet side of the heater core. This in-line restrictor extends the life of any heater core. It get discarded a list when the hoses or core get changed.
Thread starter Similar threads Forum Replies Date
Mustang5L5 Mustang5L5 DIY MS3x Thread Digital Self-tuning Forum 104
Benni614 Update on my progress with my on3 build. SN95 4.6L Mustang Tech 2
Red50Fox Constant vs. progressive coil springs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
LILCBRA LILCBRA's 87 GT convertible project (and it's lack of actual progress!!) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 20
Onesick99GT 99 Gt Progress Build 1996 - 2004 SN95 Mustang -General/Talk- 5
0 Progress thread - GT Auto to Manual Swap (and new seats!) SN95 4.6L Mustang Tech 21
rademf64 Fox progress thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
G Progress Thread My new 5.0 engine bay progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
Olivethefet Progress Thread Therapy Car-- Making Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 986
9 Progress build. 99 SVT 1996 - 2004 SN95 Mustang -General/Talk- 7
9 Anyone turbo their 3.8 sn95 Mustang ? [build progress] 1996 - 2004 SN95 Mustang -General/Talk- 5
TheFourEyedKid Progress Thread 1989 Daily Driver Build Up (probably slow progress) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
Q First Mustang GT...work in progress The Welcome Wagon 2
E Progress Thread Granny's Help and Progress Thread - 94 GT, I ain't skeered... 1994 - 1995 Specific Tech 25
A Blew my motor, new MMR 750 build in progress 1996 - 2004 SN95 Mustang -General/Talk- 14
Sweetmarie66 66 Coupe Progress 1965 - 1973 Classic Mustangs -General/Talk- 8
Mstng93SSP 94 Cobra Progress Thread (formerly Help Me Decide Thread) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 168
2/75TH RANGER Finally ! Progress On The 302 ! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
Rdub6 Progress Thread 2nd Fox Body ..... more progress to 5 lug 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 488
Gunmonkey Thot: A Work In Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
FastDriver Progress Thread Reef Blue '93 GT Turbo Progress Thread - Houston we have a problem 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 233
darkfader Progress Thread Darkfader's 93 Gt Progress- Heads are here!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 259
Slobin3d 86 Mystery Mods Progress! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 182
K '88 Lx Vert Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
reeber Progress Thread 7 Year Build Back In Progress! 1996 - 2004 SN95 Mustang -General/Talk- 4
acoddo Progress Pics / Motor Teardown 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
ConnorM37 2000 Gt Engine Swap- In Progress 1996 - 2004 SN95 Mustang -General/Talk- 12
DrakeRobinson68 Hello From Ca With A '68 In Progress 1965 - 1973 Classic Mustangs -General/Talk- 8
acoddo Progress Pictures 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
RangerJoe Nos Mini Progressive Review 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
F Progress!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
RaggedGT Progress Thread The Ragged Gt Thread-little To No Progress Made-Garage Art 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 164
rd Back At It, But Slow Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
Jaystang73 Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
87_notch_402 Fox 87 Notch Progresss 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 73
falconater Fairmont Progress? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
John Dirks Jr More Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
J.dement Neglected 2000 3.8l Restoration Progress (12.2.16) SN95 V6 Mustang Tech 0
S Progress Thread 2001 Gt Progress Thread - Stock Video 1996 - 2004 SN95 Mustang -General/Talk- 1
v8stang289 V8stang289's 86 Gt That's Taking Way Too Long -progress Thread - 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 29
91BlckGT 91blckgt's "about *&$# Time" Progress Thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 84
Crazedstang Progress Thread Slow Progress On My "illegally Abused" 1988 Gt 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 37
MrFoxNutCase Finally Some Progress On Project Smoke Grey Int. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
B Iac / Overheating Woes - Progress And Questions SN95 4.6L Mustang Tech 2
90BlueGTStang Paint Progress 90 Gt 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
2000xp8 SOLD Saleen Foxbody Progressive Rate Lowering Springs Suspension Parts 1
awilli93coupe Mini Tub In Progress!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 50
Chuckman Progress Thread Street/strip 427w In A Gt Hatch- Slow Progress 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 261
MY 85 GT Little Progress Today. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
90lxwhite Progress Threads And "tech" 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
