  • 1994 - 1995 Specific Tech
my car will not start
  • Thread starter Thread starter OrangeMustangGt
  • Start date Start date Mar 10, 2008
OrangeMustangGt
1,976
Cape Cod, MA
Mar 10, 2008
  • Mar 10, 2008
I have had this ongoing problem when my car is warm it will not start...it cranks VERY slow and clicks loudly.... I have been through 2 autozone batteries, and i just went out and bought an optima redtop....I just got back from vacation for a week and the battery was dead...
So, I have eaither a starter issue or a alt issue....something is backfeeding....and like i said it hates to start when its warm...so im leaning twords starter....anyone have any similar issues?
HISSIN50
34
129
Mar 11, 2008
  • Mar 11, 2008
But after a charge of the battery or a jump, it cranks normally? Just checking that the ground pathways are ok.
Hook up your meter in series with the disconnected negative battery cable and terminal. See what draw there is and start pulling fuses till it goes away. If it doesnt, disconnect the alternator's charge cable and see if it goes away.
Good luck Kyle.
OrangeMustangGt
1,976
Cape Cod, MA
Mar 11, 2008
  • Mar 11, 2008
Thanks for the reply...i didn't figure i would get a ton of answers on this, because it is driving me nuts trying to figure it out. First of all, it only does it when i drive for a while, so generally its at a store, etc where i get the REAL slow cranking and i have never tried jumping it because it eventually does start...but its struggling REAL BAD....
Thanks for the idea on disconnecting fusees, etc...good idea to track down what is draining my battery...
One question though, when you connect a battery, there is a spark...meaning current draw.....how much will the car draw in the off position on a normal car? I will check mine....
HISSIN50
34
129
Mar 12, 2008
  • Mar 12, 2008
I dont have a factory spec on current draw but it should be well under 100 mA (0.1 amps). Remember to repeg your positive meter lead when you go to do this.
With the slow cranking, since it only occurs when the motor is physically warm, I like your line of thinking. It's probably either a cable issue, ground issue or starter (heat soak) issue. With the cables and connections, they are less efficient when hot, so borderline stuff rears its head when it gets hot.
I generally beef up the wiring and if that doesnt fix it, have the starter bench tested (while it's hot). I might get the car nice and warm and where it wants to crank slowly (in your driveway). Toss jumper cables from the motor to chassis and one from the starter's battery post to the battery's positive terminal (if you can do this easily). If it cranks right up, you know it's time to fix cables.
Good luck bud.
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
