My daily driver is down. Need help please....
  • Thread starter Thread starter IH8BOWTIES
  • Start date Start date Feb 28, 2010
IH8BOWTIES
92
Feb 28, 2010
  • Feb 28, 2010
I have a 92 that has me stumped. I left work one day and as I pulled into the street, it died as if I turned off the key. The obvious went through my head. Ignition switch, coil pack, icm, etc. I have another car I'm restoring so I robbed some parts and had the icm tested. This car runs so I know they're good. None of these were the problem. I checked the fuel pressure and I'm getting 42psi and I've got fire at the plugs so I'm not getting fuel into the cylinders. It's like my fuel injectors just shut off. Do they have a fuse or something? I plugged the FI relay into the fuel pump and the pump came on so the relay seems ok. When I turn on the key, the fuel pump does not cycle for 3 or so seconds. Instead, it just stays running and the "check engine" light glows dim.
I dropped the tank to see if there was anything that might be obviously wrong. I changed the F/P strainer while I was in there thinking maybe that was clogged up. No luck. The only other thing that comes to mind is the PCM. I've never heard of one going out but I suppose it's possible. I've checked everything I can think of. If anyone has some insight on this, I am all ears (well, eyes). My wife is getting tired of taking me to work everyday. I'm about to say screw it and go put my order in for the 2011 GT. That would fix it for sure.
rd
3,316
63
109
Ocean Springs MS
Feb 28, 2010
  • Feb 28, 2010
Have you tried wiggling the key? Occasionally the ignition switch gets out of adjustment. My 79 did that once, and swinging keys and fob would shut the car off.
Beyond that, I would try the EEC 4 troubleshooting routine or scan it.
Also do a search one here for not starting. Jrichker has excellent information for this issue.
tb9050lx
155
ct
Feb 28, 2010
  • Feb 28, 2010
ck the ecc the fusible link ! could be blown ,had that happen to me once
tb9050lx
155
ct
Feb 28, 2010
  • Feb 28, 2010
ck the ecc fusible link , its on the starter solonoid ,it could be blown , had it happen to me once ,ck engine light would glow dim car wouldnt start,injectors wouldnt fire
Tanus
847
A to the Z
Feb 28, 2010
  • Feb 28, 2010
swap the tps
HISSIN50
34
129
Mar 1, 2010
  • Mar 1, 2010
If there is spark and there's FP, the EEC and EEC relay are getting power.
Did you try to pull codes?
As RD suggested, run JR's checklist. It's in the useful Tech sticky atop this page.
Good luck.
tb9050lx
155
ct
Mar 6, 2010
  • Mar 6, 2010
Good luck.
maybe but in my case the fuse wasnt burned all the way through and the the eec was getting power just not enough thats why the cel was dim !
IH8BOWTIES
92
Mar 6, 2010
  • Mar 6, 2010
There's a fuse to the EEC? I can't seem to find that one. Where is it? Or is it a fuse link? I'm about to throw in the towel and haul it off to the shop and pay mega bucks go get it running.
HISSIN50
34
129
Mar 6, 2010
  • Mar 6, 2010
Where did you make it in the checklist?
IH8BOWTIES
92
Mar 7, 2010
#10
  • Mar 7, 2010
  • #10
I went through it the best I could. I'm no wiz when it comes to electrical so I may have boneheaded something. The only thing I really have is a DVM. I did see that I'm getting 12v to the injectors though. I did notice a reply to jrichters' post by willysteve that said to check the 10uf electorlytic capacitor inside the EEC. I don't know where that is and would be curious to look into that.
HISSIN50
34
129
Mar 7, 2010
#11
  • Mar 7, 2010
  • #11
If you run the checklist in order, you will find the issue, and it will tell us what is good, bad or unknown on the car.
Opening the ECU is not for a novice, and not to be done unnecessarily. You said you had the EEC tested and/or installed a spare EEC anyways, no?
IH8BOWTIES
92
Mar 7, 2010
#12
  • Mar 7, 2010
  • #12
No hissin, I don't open anything I don't understand. I had the ICM tested and it passed. I installed it back on the car. I will go through the checklist again. If anything, it will give me some good knowledge of the car but I'll get there eventually.
l1k2gadd
53
Summerfield, Florida
Mar 7, 2010
#13
  • Mar 7, 2010
  • #13
What about "jumping timing"? How many miles are on the car? I know these cars have steel upper and lower timing gears on them (or one I replaced a timing chain on did). I doubt Ford is using nylon camshaft gears on any of these. Did you check to see that the #1 wire is where the distributor rotor is pointing to when the #1 cylinder is almost to top-dead-center?
IH8BOWTIES
92
Mar 14, 2010
#14
  • Mar 14, 2010
  • #14
I went back through the checklist again. I got to the part about the relay next to the computer. I didn't see any relay next to the computer located in the passenger kick panel. I do have a f/i relay under the mass air next to the f/p relay. I changed that with no luck. I know this has to be something simple that I'm overlooking. I just can't locate it. I have been through the checklist best I can.
HISSIN50
34
129
Mar 14, 2010
#15
  • Mar 14, 2010
  • #15
The EEC relay is above the computer.
IH8BOWTIES
92
Mar 14, 2010
#16
  • Mar 14, 2010
  • #16
Cool, Thanks Hissin
stang&2Birds
2,091
New England. :-) CT/MA
Mar 14, 2010
#17
  • Mar 14, 2010
  • #17
Hi.
First, you must get the EEC working. I won't matter in a a rat's *ss if you take the engine & sensors & harness and swap them out with brand new Ford parts. Your EEC is not working! And, in a major way!
One of the most basic operations of the EEC is to shut off the fuel if no signal is seen from the PIP (no rpm). Also, my guess is that you can't read codes.
So, you must concentrate on checking the voltage that goes to the EEC. You can remove the EEC from the harness and probe the harness. In fact, that's the correct and best way to do it!
Chances are that either the switched or the non-switched power to the EEC is bad. It could be many things. First, see which power is there, and then go from there.
Unless you have some electrical tech/engineering background, do not open up the EEC. Just buy a replacement if yours is bad.
stang&2Birds
2,091
Mar 14, 2010
#18
  • Mar 14, 2010
  • #18
See:
View attachment 226289 For Engine, Fuel Injection, and EEC, see:
Mustang FAQ - Engine Information
View attachment 226290 Ignition Switch Wiring schematic, in color, by TMoss:
View attachment 226291 Awesome color wiring diagram, by TMoss, for the 88-91 Mustang 5.0 Injectors, Sensors, and Actuators:
View attachment 226292 Awesome color wiring diagram, by TMoss, for the 91-93 Mustang 5.0 Injectors, Sensors and Actuators:]
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Yea, I haven't touched those pages in ~10 years. But, your '92 Stang hasn't changed in about 20 years.
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
