my OWN engine demons ... (down on power)
  • Thread starter Thread starter Synned
  • Start date Start date Sep 15, 2005
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Sep 15, 2005
  • Sep 15, 2005
Okay I am having a power problem. After the car has heated up and has been running it runs like balls. It might even be the 2nd time I start it up but that doesn't make sense. The car will hesitate, say I'm trying to pull out of somewhere and give it a little throttle it will be really slow and hesitate. When the car is gold it feels amazing, I can burn out from a stop etc. So far I have done:
Plugs
Wires
Distributer cap and rotor
o2's
fuel filter
cleaned maf and iat.
What the heck can be the problem? Can my transmission be slipping? I also get horrible mileage and im pretty sure they are related. I really really want to get this fixed. Can it be the fuel pump? I heard when they heat up they get ****ty. I'm just about to take it to a mechanic, would they be able to solve the problem?
Thanks guys, any suggestions would be great.
carbed87
215
  • Sep 15, 2005
huh, thats funny cause mine does that on the first start of the day, i know what you mean, it just hesitates, well you'll be at the top of the screen now, so mabye someone will help
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 15, 2005
  • Sep 15, 2005
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
