  • SN95 4.6L Mustang Tech
mysterious winding sound
  • Thread starter Thread starter 03reamer87
  • Start date Start date Mar 22, 2009
03reamer87
North Carolina
Mar 22, 2009
  • Mar 22, 2009
i have a 2003 GT thats making a winding sound and sounds as if a turbo is winding up?! funny thing is... i have no turbo...?
it sounded like it was coming from the transmission so i took it to a shop they completely tor it apart and ran it through all the gears and found nothing wrong...
i asked a good buddy of mine that knows cars much better than myself he gave me a few things to look at
Power steering
Possibly the rear diff?
alternator bearings
throwout bearings
if anyone has anymore possible ideas id love to hear em'
and one more quick question if i was to look into redoing my rear end.. the cars that is... and im looking to get up to speed a little quicker what kinda of gears and what gear ratio should i look for?
thanks
TeamCaffeineGT
193
15
18
Springfield, MO
Mar 23, 2009
  • Mar 23, 2009
Does the sound happen when your A/C or heat is on? Does the sound happen when you are turning at a stand still? Does the noise happen at idle or under throttle? Let us know!
RedDaemon
3,470
9
108
Atlanta, GA
Mar 23, 2009
  • Mar 23, 2009
ill bet money its your throw out bearing if your car is a manual.
does it stop when you push the clutch pedal in?
if you answer yes, you have found your problem.
N
nizzo
39
  • Mar 23, 2009
they also say that some brand of gears whines real bad, i dont remember the brand
RedDaemon
3,470
9
108
Atlanta, GA
Mar 23, 2009
  • Mar 23, 2009
he hasnt swapped out his gears yet though. from what he has said, he is still running stock gear ratio
03reamer87
North Carolina
Mar 30, 2009
  • Mar 30, 2009
It only happens when i accelerate.. and when i slow down the sound lessens... if i switch gears the sound starts all over again from a low to a higher sound, until i shift again...?
bboylobo
130
Lancaster PA
Mar 30, 2009
  • Mar 30, 2009
so if you push your clutch down, does it dissapear? does it get louder if you rev your engine. could be throw out bearing or idle pully going bad. as for rear end ratios, i have 3.73 and it worked well as a daily driver and on the track. some people go with 4.10 but i think thats too much for me. you loose more MPG with 4.10 but for the track is better for your 60'.
99RioRedVert
95
Chesapeake, VA
Mar 30, 2009
  • Mar 30, 2009
Richmond gears are the ones some people tend to get whine from.
Ford Motorsports gears are very good quality.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
