Need casting number DECODE
  • Thread starter Thread starter guywmustang
  • Start date Start date Jul 7, 2004
G
guywmustang
Phoenix, Arizona
Jul 7, 2004
  • Jul 7, 2004
I have a 66 Mustang with a motor that is not original to the car.
This casting number was found behind the intake manifold on the top of the engine. The number found was: 7R121602
I would appreciate if someone could help me decode this. Thanks!
Max Power
1,774
St Paul
Jul 7, 2004
  • Jul 7, 2004
Doesn't look like a Ford part number to me.
R
Ronstang
1,294
Houston Texas
Jul 7, 2004
  • Jul 7, 2004
Pictures would help....that number alone means nothing at all to me.
Max Power
1,774
St Paul
Jul 7, 2004
  • Jul 7, 2004
I believe the engine number is on the skirt of the block by the motor mounts. It will probably start with a C or a D or an E.
TobyGaff
211
Indianapolis
Jul 7, 2004
  • Jul 7, 2004
The casting numbers for the engine will be on the bottom of the block just above the starter. You will probably have to take the starter off to clean and read the numbers.
The numbers that you are looking at I believe tell the plant, and the production line that made the block originally. The engine casting numbers on the bottom of the block tell what casting design was used. These are the numbers you are interested in. Occassionally they are also on the drivers side front of the block just below the head, but not all blocks have them there.
M
How To Decode
  • Malcoll1
  • Mar 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
FoxChasis
F
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
