  • SN95 4.6L Mustang Tech
Need Help 03 Gt
  • Thread starter Thread starter Debonaire
  • Start date Start date Jul 22, 2016
D
Debonaire
  • Jul 22, 2016
hey guys, I have a 2003 mustang GT, and the reason why I'm here today is to see if anyone can help me figure out what's wrong with my car or point me to the right direction. The problem with my car started a few weeks ago, when I'm out for a drive and I make a complete stop, the car idles close to 1k rpm and then shuts off. It starts right back up again with no problem. I changed the fuel filter,air control valve,idle pulley,tension pulley,spark plugs,and serpertine belt in hopes that it would solve the issue, but it didn't.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 23, 2016
  • Jul 23, 2016
The next step should be a through review of the battery and charging system. You may not believe this but the motor shutting down for no reason with an easy restart could be a bad battery or loose battery cable.
Bottom line. Today's cars simply will not run right without a strong battery and charging system.
D
Debonaire
  • Jul 23, 2016
Hey thanks, I went ahead and checked the battery and cables to the best of my ability, and everything looks fine. The battery is maybe 8months old. Should I replace the battery before you recommend something else?
J
jeno_labanca
109
Jul 23, 2016
  • Jul 23, 2016
Have the battery and alternator tested before buying
Sent from my SM-N910T using Tapatalk
D
Debonaire
  • Jul 23, 2016
Just got the battery and alternator tested, both are good
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 23, 2016
  • Jul 23, 2016
Automatic or manual? If automatic does the problem only occur coming to a stop?
Are you positive there isn't a vacuum leak?
Here's some information on how to trouble shoot idle/IAC issues:
http://www.stangnet.com/mustang-forums/resources/troubleshoot-iac-idle-problems-1996-2004.13/
D
Debonaire
  • Jul 24, 2016
The car is manual, and yes only when I make a complete stop does the car shut off. Not every single time but maybe 6/10 times will the car shut off. I will check for a vacuum leak today and let you know what I found. And thanks for the link, I will clean my mass air flow sensor just to be sure
D
Debonaire
  • Jul 24, 2016
Checked for vacuum leaks and didn't find any. Also cleaned mass air flow sensor and didn't seem to solve the issue
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 24, 2016
  • Jul 24, 2016
sooooo what about the results of all the other tests called out in the resource guide?
Modular2v
3,222
23
99
oklahoma
Jul 27, 2016
#10
  • Jul 27, 2016
  • #10
Check your 02s
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
