  • SN95 4.6L Mustang Tech
Need help fast ** easy problem **
  • Thread starter Thread starter kosmos
  • Start date Start date Jun 7, 2009
kosmos
35
  • Jun 7, 2009
Ok i have a o/r x pipe, I have the mil eliminators that have worked for 2 years no problems, but today my CEL came on, so I ran the code and it came back saying word for word.
Catalyst Efficiency Low-bank 2,
well we all know I dont have no cats, so im wondering is the actual o2 sensor bad or the mil eliminator??
what do i need to do and always which 02 is it talking about since theirs 4 total 2 in the front and 2 in the rear
AdRock
521
South Texas
Jun 7, 2009
  • Jun 7, 2009
Disconnect the MIL eliminators. Clean all the connections with contact cleaner. Then put some dielectric grease in the connectors and put it back together. Reset the ECU and see if the code comes back.
kosmos
35
  • Jun 7, 2009
Im trying to see if I can find someone who has a tuner so I can just turn the rear o2 off, do you guys think that would be easier than possibly having to buy a new set of mil's? because it doesnt sound like my o2 sensor is bad because it obviously read something was wrong, so it has to be the mil's
MaxedGT
304
Surrey BC Canada
Jun 7, 2009
  • Jun 7, 2009
I've found with the mils, that everytime I reset the computer, cat efficiency codes would set after a few days of driving. But if I didn't clear the codes, the light would go out and wouldn't set again. If I cleared the codes, they would set again. So don't panik.
kosmos
35
  • Jun 7, 2009
Ok well I disconnected the negative battery terminal for 30 minutes and check engine light is off now, but it will come back on after a week of driving, that im absolutely sure of,
so you saying that if i just leave the light on it will eventually go out?!
my first thought was maybe the mil's are dirty or loose and need to be cleaned but i dont have my jack with me at the moment.
and you cant buy mil's no more if mine have gone bad, so im trying to get ahold of my installer to see if he has a tuner that i can use to completely turn off the rear o2's but if im gathering what your saying i'll just leave the light on for awhile and see what happens
kosmos
35
  • Jun 7, 2009
I noticed that they dont sale mil anymore?! well i cant get under the car at the moment but i do know that the plug in type MIL'S are sealed once plugged in so i dont know how dirty could get in their, also I cant find anybody that has a tuner that will turn off o2 sensors, all the new ones wont let you do it.......... so this is really starting to piss me off lol
I dont want to take the bulb out so lets say my mil has gone bad from years of use well what the hell do you do?!
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jun 8, 2009
  • Jun 8, 2009
Simple....you have an exhaust leak. I had this could before on a Grand Prix. I got this could months after I changed the converter. Come to find out, the bolts at the manifold loosened up and caused the upper O2 sensor reading to be way off.
96SCstang
228
novi, MI
Jun 8, 2009
  • Jun 8, 2009
ok....first off that code is for the drivers side rear o2 sensor. bank one is always the side with the number one cylinder and on our cars that is the passenger side. that code is set on a stock car when the rear o2 reads rich for too long. this means that the cat is not effectivly burning the raw fuel from the engine. now on your catless setup it is way differnent. the mil is just a devise to fool the computer into thinking that the cat is still there. so it could be either a bad mil or a bad o2 sensor like you already said. now if you can get someone to turn off the rear o2's then do it. they are not serving any purpose whatsoever right now. otherwise you will have to figure out which part is bad.
squeak93
2,319
396
164
Joplin, Missouri
Jun 8, 2009
  • Jun 8, 2009
That would be true if it were sensor one but since it is for catalyt (sensor 2) then it should just be a bad mil/sensor.
kosmos
35
#10
  • Jun 8, 2009
  • #10
I figured since the o2 sensor did pick up a problem that its obviously working fine so my thoughts go to a bad mil eliminator, so i ordered a brand new set today if it comes back its gotta be a bad 02 sensor problem solved
AdRock
521
South Texas
Jun 8, 2009
#11
  • Jun 8, 2009
  • #11
Did you even try cleaning out the connectors?
Also, you said earlier in the thread that you would try to find someone with a tuner to turn them off for you. I know you're not doing that now, but someone couldn't just turn them off for you with their tuner. You would have to buy a tuner yourself or have a shop put a chip in and turn them off in a tune.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 8, 2009
#12
  • Jun 8, 2009
  • #12
swap the connectors side to side and see if it pulls a code for bank 2.
SVT32VDOHC
3,501
28
119
Motor City
Jun 9, 2009
#13
  • Jun 9, 2009
  • #13
But it doesn't have to be a bad sensor/mil. Could be a leak that is making the snesor throw a could. If you have a leak, fix that first.
Always do free stuff first, then spend money.
squeak93
2,319
396
164
Joplin, Missouri
Jun 9, 2009
#14
  • Jun 9, 2009
  • #14
Agreed on the free fix's. But unless he has a hole in the pipe or a crack it would throw the front sensors first(there are no joints to leak after the front and before the rear sensor). The fronts are the most sensitive and will pu the extra air first. I had bad maf and it threw my front sensors and the normal "cats not working" rear code.
I say the sensor or mil has gone bad.
+1 on swaping sensor sides to see if it does the same thing.
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
  • Gulftown980x
  • Jul 29, 2026
squeak93
C
Confirming approach for P0420
  • crazyone64
  • Oct 21, 2024
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2024
89ripper
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
