  • SN95 4.6L Mustang Tech
Need quick power window help!
  • Thread starter Thread starter 9646gt
  • Start date Start date Jun 1, 2005
1 of 2 Next Last
9646gt
595
Holloman AFB,NM
Jun 1, 2005
  • Jun 1, 2005
Ok the passenger side window on my 96 gt will go down but not back up from either side of the car (either switch) I have replaced the motor with a working one and it STILL wont work..is there a realy that is easy to get to that I can check some how or something? I need to get this working before I head to work ...how much would it cost for a new realy or something to fix this problem? any help is greatly appreciated!
9646gt
595
Holloman AFB,NM
Jun 1, 2005
  • Jun 1, 2005
bump...
9646gt
595
Holloman AFB,NM
Jun 1, 2005
  • Jun 1, 2005
the window also will not roll down the from the driver side of the car..but will from pass side..someone has to have some clue of what I can check..I am completely clueless! anyone?!?
Back2Mustangs
466
  • Jun 1, 2005
My 97 Z28 had this problem and it was the actual door switch. I had to replace the switches and the windows rolled up and down faster afterwards also... a possibility, but I don't know exactly what the cause of your problem is... sorry
9646gt
595
Holloman AFB,NM
Jun 1, 2005
  • Jun 1, 2005
that may be it but I am not sure and I have my car tore apart! Guess I will be riding to work in something other than the stang..
9646gt
595
Holloman AFB,NM
Jun 1, 2005
  • Jun 1, 2005
bump..maybe more luck at modular depot
9646gt
595
Holloman AFB,NM
Jun 1, 2005
  • Jun 1, 2005
sorry double post..
4point6GT
14
Boynton Beach, FL
Jun 1, 2005
  • Jun 1, 2005
did you check and make sure all connections were ok, it happened to my drivers side, i just took off the panel and banged on the motor with a screwdriver a few times.
9646gt
595
Holloman AFB,NM
Jun 1, 2005
  • Jun 1, 2005
well both motors are fine I am guessing I watched the new one roll up and down right before it was taken out...I have tapped them and they both do the same thing..I jsut dont understand why it wont work at all from the drivers side but will roll down only from pass side..my driver window works perfect...grrrrr
T
TripleBlk
312
Cape Canaveral FL
Jun 1, 2005
#10
  • Jun 1, 2005
  • #10
It's probably your switch - cheap at "good guy" dealers ($ 19) , expensive "yacht owner" dealerships ($ 35). HTH
9646gt
595
Holloman AFB,NM
Jun 1, 2005
#11
  • Jun 1, 2005
  • #11
The guy with the parts car is going to get one for me tmrw so I can test it out and see..is it most likely the pass side switch? the reason I need to know is bc I have to make sure he gets the right one..Thanks guys
9646gt
595
Holloman AFB,NM
Jun 1, 2005
#12
  • Jun 1, 2005
  • #12
my buddies dad tested the switch and it gets power when rolling down but no voltage when pressing up...would this be a bad switch or do I have an even bigger problem?!
Back2Mustangs
466
#13
  • Jun 1, 2005
  • #13
Switch or wiring... hard to say which switch it is(driver or passenger) because of how they are wired in series... My buddies 92 LX that I rewired for him proved to be the exact same as my Z28 problem... He thought the actuators were bad, but the previous owner hacked the wiring up really badly so after I was finished putting it all back together both windows work flawlessly...
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 1, 2005
#14
  • Jun 1, 2005
  • #14
Slam the door hard a couple times.
Wait a while...
When it cools down it will work.
The rubber is impeding the windows movement and making the motor or relay over heat. Fix the rubber to fix the problem...
9646gt
595
Holloman AFB,NM
Jun 1, 2005
#15
  • Jun 1, 2005
  • #15
Wait a while...
even with the motor not installed and just hooked up out side of the door it will not operate when pressing the up button ...neither motor but I know the one is practically brand new...
98BLKGT
322
Chicago area
Jun 1, 2005
#16
  • Jun 1, 2005
  • #16
Wait a while...
hehe I just had the same problem with my drivers side window. It finally started working after I got everything apart. Someone was also talking about a relay sticking when hot. I guess my cooled off but yours might be stuck. Guy at autozone told me I should try to run a 12v source directly to the motor or the switch to try to locate the problem. I never tried it though.
damacman
529
Phoenix, AZ
Jun 2, 2005
#17
  • Jun 2, 2005
  • #17
The power window system in your vehicle more than likely does not use relays. Rather, both switches rest at ground. Pressing the UP button sends 12 volts to one of the motor wires, the other rests at ground. Pressing the DOWN button sends 12 volts to the other motor wire, while the other rests at ground. The drivers and passenger switches are connected in series so that either can control the same motor.
Now that you've determined that one of the switches has no power when pressing UP it is more than likely defective switch. Based on your description, I'd have to say the passenger switch is defective.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jun 2, 2005
#18
  • Jun 2, 2005
  • #18
it's one of the switchs probally the drivers switch.
9646gt
595
Holloman AFB,NM
Jun 2, 2005
#19
  • Jun 2, 2005
  • #19
Update...I replaced both switches with working ones and nothing at all has helped....I tried bothe xisting switches for pass side and the replacement for apss side all in my drivers side switch plug in and they all worked the drivers window great..I really need to figure this out so I can get it fixed and get the car back together..anyone else have any ideas?
9646gt
595
Holloman AFB,NM
Jun 2, 2005
#20
  • Jun 2, 2005
  • #20
BUMP...
Sorry I hate to keep doing this but my car must be back together tmrw and after that I have no garage to work in and nothing but rain in the forecast
1 of 2 Next Last
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
Rear window failure
  • Moondog2178
  • Jul 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 22, 2025
Moondog2178
