Need some Brake Help
  • Thread starter Thread starter 1988WHTGT
  • Start date Start date Mar 12, 2006
1988WHTGT
270
Guyton, GA
Mar 12, 2006
  • Mar 12, 2006
Ok, my brake fluid is about as black as it can get. I am wanting to change it. Whats the best way to drain the system? And what brake fluid should I use to put back in? Thanks.
P
PRO50SC
1,012
Olney, Maryland
Mar 12, 2006
  • Mar 12, 2006
Dot 3 fluid. Syphon the fluid out of the m/c reservoir and poor in new. Now start the bleeding process. r/r, l/r, r/f, l/f. Bleed each wheel until the fluid runs clean. Check periodically to make sure you don't run the m/c dry.
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Mar 12, 2006
  • Mar 12, 2006
Don't let the system go dry. Just start adding new fluid at the MC and bleed each brake line until clear fluid comes out
1988WHTGT
270
Guyton, GA
Mar 12, 2006
  • Mar 12, 2006
Sounds good. Thanks guys
1988WHTGT
270
Guyton, GA
Mar 12, 2006
  • Mar 12, 2006
Oh yea, a friend of mine was telling me about dot 5 and how it has a higher boiling point. Should I stay away from that and just do dot 3?
xpeteyjtx
108
Taunton, MA
Mar 12, 2006
  • Mar 12, 2006
I am not an expert, but DOT 3 is recommended and it even says it on the cap (I think). Even if I heard good things about DOT 4-5, I would still use the 3.
D
Daggar
3,902
  • Mar 12, 2006
Ideally, a two man job. Someone to keep filling the reservior while you bleed is a def plus.
P
PRO50SC
1,012
Olney, Maryland
Mar 12, 2006
  • Mar 12, 2006
Unless you're using the car for auto cross there is no need to use anything else other than dot 3.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 12, 2006
  • Mar 12, 2006
Garden Sprayer Pressure Bake Bleeder
1 each pump type garden sprayer, 1 - 1 ½ gallon capacity (size doesn’t matter much, it just has to be cheap and small enough to be easy to work with)
6-10 feet 3/8” clear plastic tubing
1 each ¼” brass pipe tee
1 each ¼” pipe to 3/8: hose adapter
1 each pressure gauge 0-60 PSI or so – all you’ll ever need is 5- 10 PSI, so the gauge range doesn’t have to be high.
1 each large rubber stopper – this is the hard part to find. It may take some searching to find one that is a snug push fit to the inside of the filler port on the master cylinder. You can use silicone rubber to seal a brass fitting to an old master cylinder cap, but they tend to leak too much.
Home Depot or Lowes has some ¼” brass pipe stock that is continuously threaded in the electric lamp repair department, along with the brass nuts that go with it. This is better than a pipe nipple, since the nuts can be used to secure the pipe in the cap or stopper.
OR if you can’t find the threaded pipe stock,
1 each ¼” nipple, 1 ½”- 2” long
The rubber stopper needs a hole drilled in it for the ¼” pipe nipple or threaded pipe stock. After you drill the hole, use some silicone gasket sealer to seal the pipe nipple as you push it into the rubber stopper. If you used the threaded pipe stock, use the nuts to secure the stock into the stopper.
If you can’t find a suitable rubber stopper, an old master cylinder cap can be used. Drill a ½” hole in the center for the pipe fitting. Cut the brass pipe stock to about 1”- 1 ½” long, the exact length isn’t too important. Push it through the hole in the master cylinder cap and thread one nut on top of the pipe stock where it sticks though the cap. Put another nut on the other side of the cap to lock the pipe stock in place. Apply some silicone rubber gasket sealer to both sides and when it is dry, screw the ¼” pipe that sticks out of the top of the cap into the tee.
Remove the sprayer hose and wand from the garden sprayer. You may find it easier just to cut the sprayer hose off short and connect it to the 3/8” plastic tubing. The idea is that the 3/8” tubing connects to the pickup tube inside the sprayer in a reliable, leak proof fashion. Another alternative is to remove the spray nozzle from the end of the spray wand and connect the 3/8” tubing to the wand. This leaves the hand valve in place and may be useful to start/stop the flow of brake fluid.
The 3/8” plastic tubing connects to the pipe tee using a push on hose barb type adapter. The pipe tee has one port for the gauge, one for the 3/8” hose and the other to connect to the rubber stopper or master cylinder cap that you modified.
Fill the pump sprayer with a quart of brake fluid. Set the garden sprayer on the ground and screw the pump handle down tight, and pump until brake fluid fills the plastic tubing. Then put the modified stopper or master cylinder cap on the master cylinder and pump slowly to make sure that nothing leaks or pops loose. No leaks, continue pumping until you get 5-10 PSI. Put a 6”-12” length of clear plastic tubing on the bleeder ports. Then open the bleeder ports on the wheel cylinders one at a time and bleed until the bubbles are gone. I use a 2 liter soda bottle with a coat hanger to catch the fluid . DO NOT REUSE THE OLD BRAKE FLUID. Repeat the process until you have finished all 4 wheels. You will have to pump the sprayer several times to maintain the 5-10 PSI needed to do the job. When finished bleeding, loosen the pump handle to relieve the pressure, remove the stopper/modified master cylinder cap and test the pedal.
Tonys96Cobra
professional deer "mounter"
Oct 28, 2005
29
Syracuse
Mar 12, 2006
#10
  • Mar 12, 2006
  • #10
Whatever you do, DO NOT USE DOT5!!!!!! DOT3 or DOT4 ONLY!!
C
criticman
723
Rome, GA
Mar 12, 2006
#11
  • Mar 12, 2006
  • #11
JRichker's setup, in a pre-assembled form for lazy people: http://store.summitracing.com/default.asp?target=partdetail.asp&part=MVP-0107
Mustang5L5
Mod Dude
Feb 18, 2001
43,372
18,120
224
Massachusetts
Mar 12, 2006
#12
  • Mar 12, 2006
  • #12
Yup. don't use the DOT5, stick with 3
1988WHTGT
270
Guyton, GA
Mar 12, 2006
#13
  • Mar 12, 2006
  • #13
Will do. Thanks for the help everybody
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Mar 13, 2006
#14
  • Mar 13, 2006
  • #14
Ford has some High Performance Motorcraft Brake Fluid and it has excellent properties and is not priced bad at all.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 11, 2026
keel
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
