new 1992 5.0lx need some advice
  • Thread starter Thread starter 1.8kmint
  • Start date Start date Jun 1, 2007
1.8kmint
47
Middletown, CA
Jun 1, 2007
  • Jun 1, 2007
I just bought a new 5.0 1992 stang lx with all stock parts except for a high performance k&n cold air intake and the shocks have been replaced with gas-a-justs... Now heres the weird thing, I've been looking at the exhaust and the pipes have been cut off just under the wheels and replaced with short pipes facing downward toward the ground(possibly to pass smog would be my guess) ... Not quite sure if it is the stock system but i know it is 2.5 inches all the way until the cut off tailpipes which go down to 2" If someone could recommend what i should do about this it would be greatly appreciated... If i should just replace the whole exhaust systems if any1 has any good suggestion for what i should put in feel free to post... Looking to spend about 150-400 on new exhaust system if needed
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jun 1, 2007
  • Jun 1, 2007
well if you want to run the pipes the way they were from the factory just buy a cat back set-up. this will come with the axle over pipes tail pipes and the mufflers with the short section of pipe that mounts to the h-pipe.
1.8kmint
47
Middletown, CA
Jun 1, 2007
  • Jun 1, 2007
hmm well, what would the advantages would be(if any at all) if say i put in a flowmaster system(or some other high performance system) the same sized diameter piping and extended the tailpipes all the way out the back in a duel exhaust?
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jun 1, 2007
  • Jun 1, 2007
I doubt there would be much advantage performance wise. Those 2 inch dumps are a little small though. One benifit would be that the exhaust is being expelled past your occupyed compartment. This means less exhaust fumes making it into the vehicle will stopped or idling.
1.8kmint
47
Middletown, CA
Jun 1, 2007
  • Jun 1, 2007
So cut them off and weld new tailpipes on or go whole new system?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jun 1, 2007
  • Jun 1, 2007
yea just cut them off and weld in new tail pipes, does the car have flowmasters or stock mufflers ?
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
314
281
134
Apache Junction, AZ
Jun 1, 2007
  • Jun 1, 2007
Ehh ... I wouldn't bother trying to weld new pipes onto those hacked-up muffs. For one, it'll be a sloppy job, at best, and secondly, 2" is way small.
Cheapest route would be to order a Jeg's cat-back exhaust (less than $200) and bolt that sucker under there. Comes with all the bolts, hangers, tailpipes, flow tubes, and two mufflers that you'll need. If you've got a couple of ramps or some decent jackstands and a basic, BASIC set of sockets/wrenches, you can tackle that puppy in a couple of hours. If you want something that sounds close to stock but looks/fits good and works well, but won't break the bank, you could spring for a Dynomax Super Turbo cat-back system. Otherwise, if you just want balls-to-the-wall sound and flow, order a Pypes Violator cat-back system and you will be soooooooo lovin' it.
Whichever system you go with, the end result will...
1. Sound "cleaner";
2. Not kill you (or your passengers) with exhaust fumes;
3. Be street legal in most states (dumps, which is what your current setup sounds to be, are a no-no in a lot of places);
4. Look better (just my opinion);
5. Mayyyyybe gain you a tiny bit of power by opening up the exhaust system a bit more, if the mufflers you've got on right now are 2" inlet/outlet sized.
1.8kmint
47
Middletown, CA
Jun 1, 2007
  • Jun 1, 2007
Im pretty sure there stock mufflers but what i mean when i say the tailpipes are 2" is that the whole piping under the car and everything else in the exhaust system is 2.5" its just these weird short little tailpipes go from 2.5" to 2" at the tips. I was thinking maybe go with this http://www.americanmuscle.com/8793lx-9495gt-mac-catback.html not sure how well it will weld and fit to the stock stuff though
M
MustangOwner
Banned
Dec 13, 2006
160
  • Jun 1, 2007
Buy a Cat-back system such as Flowmaster, Mac, Maganflow or some other one. Maybe even check ebay for a used one if you dont want to spend alot.
C
caduck
23
Springfield, Or
Jun 1, 2007
#10
  • Jun 1, 2007
  • #10
I think the mac setup sounds pretty darn good thats what I have with 2.5" tail pipes. I know around town I get double takes from other 5.0's that run flowmasters the Mac's just have a deeper tone to them. I am sure you could find a audio clip somewhere online if you do a search.
HISSIN50
34
129
Jun 1, 2007
#11
  • Jun 1, 2007
  • #11
I agree. I have Mac front to back on the 94 and really really like the low tone and 'burble'. Anything more and it would be on the verge of dump truck. I like it.
The 2 chamber flowmasters I have on the 88 are higher pitched IMHO. I dont like the sound as much (when under load) but that's a personal thing.
If you're doing it on the cheap: you have a bud whom welds and can find some clean used tails (new ones cost a grip), that's something I'd consider. People ditch stock catbacks all the time - I'd take their tailpipes or entire catback if offered.
Oh, DonJohn's website has exhaust clips.
Good luck.
Drinknbuddy
39
Chicago IL
Jun 2, 2007
#12
  • Jun 2, 2007
  • #12
if you get this catback system you shouldnt have to do any welding.. it bolts right to your h pipe. its a do it your self kit... just bolt it up and go..
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Yesterday at 5:04 PM
alutwon
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
