new 306 fired right up!
  • Thread starter Thread starter Jason 302
  • Start date Start date May 26, 2004
Jason 302
685
71
68
Newark, Ohio
May 26, 2004
  • May 26, 2004
Well, finally got my 306 in this weekend. Had a little delay as I stripped a thread down in the the intake for the upper. Had to drill and retap and find a bigger stud. Moment of truth came she cranked over a couple seconds and then barked, ran a little rough untill we found the sweet spot on the distributor. Set the timing around 14*, adjusted the idle screw, filled the radiator, and checked for leaks. Oil pressure hangs aroung 50-55 at idle and shoots up a little past 60 when revved. Temp stayed right below 200* the whole time. Has a nice lope at idle, revs cleaner, faster, and harder than the stocker and will only get better as it gets broke in. Unfortunatly the X-pipe didn't quite bolt up to the cat-backs right and they were rubbing the control arm so I couldn't drive it, plus I need to tie the O2 extensions out of the way. Seems to be running a little rich even though I kept my stock injectors and MAF and only bumped it up a pound or two. Overall I'm very pleased with my first engine rebuild and can't wait to see what she's got!
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
May 26, 2004
  • May 26, 2004
awesome...congratulations man. im gonna do that one day...haha, yeah one day when i have some money
87'GTstang
1,025
  • May 26, 2004
What parts/kit did you use?
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
M
i keep having to adjust timing. wtf?
  • mostsmooth
  • Jan 15, 2021
  • 1994 - 1995 Specific Tech
4K
1994 - 1995 Specific Tech Mar 20, 2021
General karthief
P
Just arrived with a 1965 289 and a 1973 Mach I - and a vacuum leak solved
  • Peter C B
  • Jun 3, 2019
  • The Welcome Wagon
The Welcome Wagon Jul 23, 2019
trentb
T
M
I really wasn't expecting this....... First time Mustang owner.......
  • Mikedd969
  • Nov 27, 2019
3K
1996 - 2004 SN95 Mustang -General/Talk- Nov 28, 2019
Mikedd969
M
