New 92 Gt Aod Help!!!!!
  • Thread starter Thread starter stangstalx
  • Start date Start date Sep 15, 2012
stangstalx
75
north carolina
Sep 15, 2012
  • Sep 15, 2012
I have just brought a 92 gt clean as ever besides small dings in the hood. It only has bbk CAI and ford racing wires. My goal is to make it in the 7s at the 1/8th mile strip. I have just recently got a mac o/r hpipe with spintech dumps. I seriously hate how the auto drives from being used to a t5. what would be best to do for the aod I hear a converter,manual valve body,cooler,shift kit and shifter and of course gears. would it be cheaper to swap the t5? And please how do i get rid of the loud fan sound at high rpm???
pearlnotchback
5 Year Member
Dec 18, 2011
319
44
59
Tennessee
Sep 15, 2012
  • Sep 15, 2012
Pull the AOD and build you a C4 with around a 3200 stall and 3:73s in the rear
stangstalx
75
north carolina
Sep 16, 2012
  • Sep 16, 2012
and still be a decent daily driver?
HISSIN50
34
129
Sep 16, 2012
  • Sep 16, 2012
Congrats on the new ride!
Swap to a 3G/6G alternator and E-fan and controller
89BlackGTvert
27
  • Sep 16, 2012
Keep the AOD, do a VB, converter. I love manuals also. So I did a full manual valve body with ratchet shifter. I love it, best of both worlds
Sent from my PI86100 using Board Express
pearlnotchback
5 Year Member
Dec 18, 2011
319
44
59
Tennessee
Sep 16, 2012
  • Sep 16, 2012
Ya as long as you dont have to commute 30 miles each way back and forth the work because with a c4 you lose over drive.
I had a 90 Gt back years ago with a c4 and drove it almost everyday. The C4 is a much stronger and lighter transmission than the AOD. Its all in what you like.
stangstalx
75
north carolina
Sep 16, 2012
  • Sep 16, 2012
ok cool my 90 lx didnt make that fan sound when I had electric fans. But yea I dont drive far often the drag strip is a bout 25 miles from home so the C4 should be fine and what is the best shifter to replace the ugly stock one?
pearlnotchback
5 Year Member
Dec 18, 2011
319
44
59
Tennessee
Sep 16, 2012
  • Sep 16, 2012
When i was running my C4 i used a Hurst quarter stick. It looks oh so nice tucked down in the factory console. Easy to use also. When you take off in first just push it up to second and squeeze the handle and push up once more for third. If you swap to a C4 you will have to change to a 157 tooth flywheel. Also you will have to swap the tranny lines and run a vacuum line down to the valve on the side of the transmission. The AOD crossmember will work but you will have to fab up an extension because the C4 is a hair shorter. Ive actually seen now you can buy an adjustable crossmember just for this. I would put a C4 in my notch if I didnt live out in the sticks 30 min away from everything. I sure miss cruising through town and everytime i shifted into secound it would bark the shiz out of the tires no matter how fast I was going. The C4 and 3:73 make a hell of a combo.
stangstalx
75
north carolina
Sep 16, 2012
  • Sep 16, 2012
sounds like it will be awesome! but gettin it to hook will be 1st on the list. I just need a parts list and start checkin off. upper and lowers springs struts trac lock tires gears. Lakewood is all i know not to sure about those things as in set up
pearlnotchback
5 Year Member
Dec 18, 2011
319
44
59
Tennessee
Sep 16, 2012
#10
  • Sep 16, 2012
  • #10
Back in the day when i built my GT all I used was a set of lakewood front struts and the rest of the suspension was stock. I removed the quad shocks and got a set of 26.0 MT E.T. street slicks and it hooked like a champ.
stangstalx
75
north carolina
Sep 16, 2012
#11
  • Sep 16, 2012
  • #11
good so I can save up more
New combo
  • 87slow.0
  • Oct 19, 2022
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2022
87slow.0
SOLD For Sale 92 Mustang Notchback Complete Rebuild in 2019
  • pearlnotchback
  • Jun 21, 2021
4K
Fox Body Mustangs For Sale (1979-93) Jun 24, 2021
Steel1
My New-to-me 1989 GT (Tips, suggestions, advice all welcome)
  • Realblaxxican
  • Mar 9, 2021
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 16, 2021
Realblaxxican
4.6 2v SOHC 2k rpm Idle, help reading engine data
  • 02stanggt53
  • Aug 8, 2020
  • SN95 4.6L Mustang Tech
5K
SN95 4.6L Mustang Tech Dec 4, 2020
Shuttleman83
M
New guy here from SE Pa
  • magnum517
  • Feb 23, 2020
  • The Welcome Wagon
The Welcome Wagon Mar 8, 2020
magnum517
M
