new fuel injectors?
  • Thread starter Thread starter blkstangman88
  • Start date Start date May 5, 2004
blkstangman88
646
  • May 5, 2004
i have a almost completely stock engine, stock heads and intake on my 88 gt mustang. well i was wondering if its a good idea to get new little bit bigger injectors or is it just a worthless idea unless i have more hp? any comments? if i could what size would be a good idea?
mustangsquared
828
new bern nc
May 5, 2004
  • May 5, 2004
stock everything, stay with 19lb injectors....24 would require a AFPR and you would have to drop the FP low say 35-37 lbs and then the spray pattern would be short and you would not get a good mix. Performance would hurt bad. Get a better intake, heads, TB, and MAF and then you can go to 24lbs injectors (still will need a AFPR set to 39 lbs)
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Fuel Fuel injector cleaner?
  • Creomod
  • May 29, 2026
Fox 5.0 Mustang Tech May 30, 2026
evintho
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
