New to this year mustang and I have questions on rims and electrical
Apr 3, 2019
25
Maine
#21
Here is the fuse box schematic, check power at the fuse, switch. I suspect a possible ground problem.
Would a ground problem allow the hazards to work? Would it be worth pulling out the headlight assembly from the front and checking? The rear of the car has the stock light assembly. In your post, the fuse box schematic didn't show up. I can google one. How would I check the switch? I don't see how the hazards would work, but not the turn signals. Sorry for how tedious all my questions are. I am a complete dolt when it comes to electrical. I found a textbook from one of the automotive schools. I'm trying to teach myself, but it is hard to learn on a 1991 car!
Thanks for your help!
General karthief
Mod Dude
Aug 25, 2016
11,251
3,425
193
polk county florida
#22
Apr 3, 2019
25
Maine
#23
ok, thanks for the schematic. I am wondering if there is a problem with the racer boy headlight assembly.
Aug 24, 2010
134
10
Uniontown, PA
#24
Since you have nothing when you activate the switch I would start there and trace it back. I would guess the problem is closer to the fuse panel or multifunction switch rather than at the headlight harness.
Apr 3, 2019
25
Maine
#25
The new switch works with wipers, etc. You still think that may be the problem?
General karthief
Mod Dude
Aug 25, 2016
11,251
3,425
193
polk county florida
#26
I think you need to channel your inner electrical mojo and start with tracing wires. The multifunction switch is new and is getting power start there, find the turn signal power wire. Check power at flasher, fuse. Follow the power.
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
26,658
2,404
224
73
Dublin GA
#27
Hello
We have a car that is new to us and the turn signals never worked. We have swapped the flasher relays and it does not change the fact that the hazards work, but never the turn signals. We exposed the wires, both hazards and by steering column and they all look fine. Pinching and pushing them changed nothing. The car has some type of aftermarket headlight units, but all of those wires appear to be fine.
Help!
87-95 Mustang Turn signal troubleshooting
Please note that the wire colors changed periodically; be sure to use the wiring diagram for your year car!
The ignition switch is also known for creating turn signal problems. Make sure the ignition switch and wiring are in good shape as a first item to check. This is especially true if you are having problems with things like the radio and heater/AC blower.
Ignition switch wiring
Some of the symptoms of ignition switch problems are things that don’t work or are intermittent like radio, turn signals, wipers or heater. The auto parts stores sell the switches for $13-$15.
While you are working on the switch, check the wiring and connector closely. A replacement connector with new wiring pigtails is available from most auto parts stores
AutoZone and Advanced Auto Parts have the same Part Number: 434 - may have to order, not always in stock
Advanced Auto Parts alternate part number: PT5534
If just the plastic shell is broken, a small jewelers screwdriver inserted from the front will release the contacts from the connector shell. Do this one wire at time and insert the wire and connector you removed into the same position on the replacement connector shell.
Saleen0679 was nice enough to dig this up for us awhile back: Replace a 1979-1993 Ignition Switch Assembly
Torx bit set from Advance Auto Parts
Autocraft torx bit set – have small hole in tip for tamper proof screws.
Part No. AC571/W1386 Cost approx. $12 +tax
Keep in mind that the flasher on the front of the fuse panel is for the hazard flasher. Locate the turn signal flasher, depending on the model year it may be behind the radio or on the backside of the fuse panel or behind the glove compartment.
Turn the ignition switch to Run; the engine does not need to be running for these tests. With the turn signal flasher removed, test the pink/orange wire for 12 volts.
Set the voltmeter to DC volts and select the scale that is closest to 12 volts. Clip one voltmeter probe on the bare metal part of the car body for a ground and put the other probe in the turn signal flasher socket contact that has the pink/orange wire. You should see about 12 volts.
No 12 volts present: replace the fuse and check for 12 volts again as described above. Do not turn the ignition switch off if you are testing for voltage.
Still no 12 volts, pull the fuse and test the #5 fuse socket contacts for 12 volts. One contact will have 12 volts. One probe is grounded, the other probe gets stuck in the fuse contacts. Test both contacts for 12 volts.
No 12 volts on either fuse contact, the ignition switch or ignition switch wiring is suspect. Move things around so that you can get to the backside of the ignition switch wiring connector with the ignition switch still connected to it. Make sure that you don't turn the ignition switch OFF while you are testing it. It still needs to be in the Run position. Look for 12 volts on the large gray/yellow wire. No 12 volts and you have a bad ignition switch or some bad wiring. Wiggle the large gray/yellow wire to see if it gets or loses voltage while you are checking it.
Diagrams courtesy of Tmoss & Stang&2birds
Fuse box layout
Once you have located the turn signal flasher, remove it from its socket and jumper the socket contacts together. Turn the ignition switch to Run and try both left and right turn signals. They should come on steady if you have good 12 volts to the pink/orange wire. If the lights turn on steady and bright, that means the flasher is suspect. If you find one more bulbs do not come on steady and bright, then you have either a bad bulb, bad ground at the bulb socket or a corroded or bad socket.
If you still have problems, then it is the multifunction switch, or its wiring; that is a case of last resort.
Multifunction turn signal switch:
Before you think about replacing the multifunction switch with one from the junkyard, here are some things to be aware of...
The problem is more common in GT models because they had fog lights on the same power wiring as the headlights. Ford undersized the wire and that caused problems.
A word of caution about multifunction switches is in order here. The multifunction switch (high/low beam, wiper, turn signals) are different for different years. 87-89 will work in any 87-89 car. The 90-93 switches only work in 90-93 cars. You can't put an early model switch in a late model car, nor can you put a late model switch in an early car.
Supposedly you can move the pins around to make the switches work in model years that are different from the car the switch came out of. I cannot verify that and haven’t tried it.
Other possible problem sources for the turn signal & headlight malfunction are the ignition switch, multifunction switch and the plastic shell that holds the turn signal wiring connector pins.
The following diagram is for 87-89 model cars.
Turn signal switch wiring:
The following diagram is for 90-93 model cars.
The following diagram is for 94-95 cars
25
Maine
#28
Wow, thanks for all of this. I am out of town until Sunday, I will get on this and get back to you! Too bad I have already replaced the whole assembly!
Thanks!
Apr 3, 2019
25
Maine
#29
Yes, for sure. I have always shied away from electrical. Now I'm being forced to learn it. I already posted that I'm away for a day and a half, so I will be getting to this on Sunday. I was our last night rechecking the fuses, hoping we had missed something. Fuses are still good.
Apr 3, 2019
25
Maine
#30
OK, we are messing with this. We have determined that we do not have power at the fuse. Does that make sense? I cannot ge power at the turn signal flasher. Of note, the "hazards" that blink on this car are the inboard lights, not the outer where I would suspect they would flash.
Also, the new stalk seems to turn the wiper motors on when going to the up position, and not the down. Sorry to throw that into the mix.
Apr 3, 2019
25
Maine
#31
Thanks for all this information, I have to replace the ignition switch assembly. You guys are great, I was wondering how to get those torx bits out! The write up walks me through it, thanks!
Apr 3, 2019
25
Maine
#32
I replaced the ignition module. I now have the heater blower motor and power to the turn signal fuses. I also do NOT have power at the turn signal flasher. I can't find a ground fault. Where else to look? I certainly could have missed a ground issue. Would the new headlight assembly be an issue? Also, the hazards flash the middle lights, not the lateral ones. I feel like I am getting close...
