Nitrous bottle bracket install questions...
  • Thread starter Thread starter BYRDPE
  • Start date Start date Nov 2, 2007
BYRDPE
1,556
Memphis,Tn.
Nov 2, 2007
  • Nov 2, 2007
For those of you that are running nitrous, how and where did you mount your bottle brackets?
Did you drop the tank? What's the easiest way to do this w/o using sheet metal screws?
Thanks
RYC CUKR
1,437
Orlando
Nov 2, 2007
  • Nov 2, 2007
I dropped the tank. Marked where i wanted the bottle and brackets to go. Drilled them out and bolted the brackets in using the nylon locking nuts so they never come loose.
SuperStang83
1,693
Boyertown, Pa
Nov 3, 2007
  • Nov 3, 2007
I helped a buddy before and we dropped the tank.
J
JamesB88
228
North Kansas City
Nov 3, 2007
  • Nov 3, 2007
I set my tank down where i wanted it with the brakets attatched, and used flat headed bolts markthe spots with a marker then tack welded the 4 bolts to the floor board. Seemd to work pretty good, no holes in the car, and i can knock the bolts back off if i want to ever not have a bottle mounted back there.
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
