Nitrous kit off of another car?
  • Thread starter Thread starter Codydubb
  • Start date Start date Feb 8, 2013
Codydubb
149
9
18
Preston, Id
Feb 8, 2013
  • Feb 8, 2013
know someone selling a nitrous kit off of a 90 5.0 its a zex kit but there are no numbers on the NMU to identify what kit it actually is. so my question would be how to identify it and/or will it work on my car regardless? i dont really know how each individual box works i know they all run off the TPS, so i was assuming it may work?
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Feb 8, 2013
  • Feb 8, 2013
wet or dry?
89stang1
Stroked and Juiced
730
234
74
nj
Feb 8, 2013
  • Feb 8, 2013
I have Zex 82015 dry kit look that up and see if it matches what you have if thats it. Then it will work on your car yes it runs off the tps but i would research a full set of instructions online before using
Codydubb
149
9
18
Preston, Id
Feb 8, 2013
  • Feb 8, 2013
srtthis said:
wet or dry?
Wet
srtthis
5,129
1,666
204
Maryland
Feb 8, 2013
  • Feb 8, 2013
it should work fine... those box's are pretty much universal as far as i know. power ground and TPS voltage. just need to set the TPS voltage to come on @ WOT. then everything is in the box. 2 lines in 2 lines out.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Feb 8, 2013
  • Feb 8, 2013
itll work, just go to zex website to look at the jetting options before you spray
Codydubb
149
9
18
Preston, Id
Feb 8, 2013
  • Feb 8, 2013
the fogger and everything should be the same right? Just different jet sizes?
srtthis
5,129
1,666
204
Maryland
Feb 8, 2013
  • Feb 8, 2013
Everyone rates the jets different... Find what size zex rates the shot you want. If you put it on a dyno and its fat go down a few jet sizes on the fuel
Codydubb
149
9
18
Preston, Id
Feb 8, 2013
  • Feb 8, 2013
sounds good ill take it to get a dyno tune before i spray it
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Electrical need help with a part number
  • alutwon
  • Jan 27, 2026
Fox 5.0 Mustang Tech Jan 27, 2026
alutwon
Fuel Pressure Regulator rebuild
  • Scrapla347
  • Feb 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 24, 2025
89ripper
G
In expensive ceramic coating
  • gray owl
  • Jul 12, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All Aug 18, 2026
NotaVegetarian
N
