Nitrous Leak
  • Thread starter Thread starter lxwants12's
  • Start date Start date Sep 1, 2005
lxwants12's
506
  • Sep 1, 2005
My zex bottle is leaking at the seam where the valve meets the bottle , can i use any valve or does it have to be zex?
also has any1 had this problem is there a way to fix it(o ring, teflon tape??)
if not where can i get the valve?
loud 95
562
Milwaukie, OR
Sep 1, 2005
  • Sep 1, 2005
I would not use any old valve...as I read your post, it sounds to me like the valve itself is not the problem, but rather, the seal between the outer portion of the valve and the neck of the tank. If this is the case, the valve assembly can be pried out and re-sealed. If there is an industrial air supply shop or a scuba shop in the area, I would take the tank in. The employees there should be certified to fix it. You could do it yourself, though I don't remember what sealant is used. I have encountered this problem in CO2, compressed air and nitrogen tanks through the course of my paintball playing. It is an easy fix, though it is one that needs to be done right.
lxwants12's
506
  • Sep 2, 2005
Yea makes lots of sense thanx for the advise
OutLawSE
1,370
NJ
Sep 2, 2005
  • Sep 2, 2005
Its the perfect time to replace the valve with a High flow valve from NOS.
Thats what I did when I bought my Zex kit.
G
getusummm
156
  • Sep 3, 2005
There is an o-ring on the valve. It seals on the bottle. The valve must be removed to replace the oring. It is a simple task that can be done at home. Just remember, the bottle MUST be empty.
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
M
Idle control valve
  • miser143
  • Oct 31, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 1, 2026
General karthief
