No Fuel Pressure
  • Thread starter Thread starter 65FBE2
  • Start date Start date Jul 13, 2007
65FBE2
283
Minnasnowta
Jul 13, 2007
  • Jul 13, 2007
I have a wierd problem, The car starts fine then over about 5 min's you can watch the fuel pressure slowly drop from 6 psi to 0. I have changed the fuel line to a 3/8 line and I know there are no kinks, I just changed the fuel pump to a new Carter HP, I have removed the fuel pick up from the tank and made sure there were no problems with the inlet. I have blowen air threw the line from the front to the back and all is clear. The fuel filter is clean. the only thing I can thik of that I haven't looked at is the accentric on the front of the cam but I have never heard of that failing. What else is there? Has anyone seen this before?
rbohm
6,698
550
204
tucson,az
Jul 13, 2007
  • Jul 13, 2007
does the engine continue to run? if so then perhaps the gauge is bad. if not then you may have a vapor lock problem.
65FBE2
283
Minnasnowta
Jul 13, 2007
  • Jul 13, 2007
The motor will still run but only at idle. I just put a gas can at the rear of the car and unhooked the fuel line from the tank, placed a long rubber hose on the fuel line and put the other end into the gas can to rule out any in tank problems. Same result. This is a factory 3/8 pre bent fuel line and the car ran fine for about a year. I can't believe it just started to vapor lock out of the blue.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jul 13, 2007
  • Jul 13, 2007
Try swaping the pump out ? Does that pump have a built in filter like the stock pumps do ? Not to insult you but it could happen... did you put the filter in backwards ?
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
