No head light
  • Thread starter Thread starter FastFox21
  • Start date Start date Oct 5, 2020
F
FastFox21
Porter Tx
Oct 5, 2020
  • Oct 5, 2020
So I was driving home in the dark and I had both of my light switches on in my 1992 fox-body and they won’t turn on nor my parking light and my hazards won’t turn on in the front either. I don’t know what to do please help!
General karthief
Mod Dude
Aug 25, 2016
28,118
10,736
213
polk county florida
Oct 5, 2020
  • Oct 5, 2020
Check the fuses?
Also pop the head light switch out and inspect the connector, they are known for overheating and melting the connector, is this a GT, I ask because you say 'both switches'.
Reactions: Wayne Waldrep
Blown88GT
2,283
524
164
Palm Beach Gardens, FL
Oct 6, 2020
  • Oct 6, 2020
GT or LX?
If GT, were the fog lights on?
There was a TSB on this.
Ford TSB 89-17-11 says this is caused by overheating in the headlamp circuit. It's a phenomenon affecting '83-'89 Escorts, '83-'87 EXPs and '87-'88 Mustangs. You'll need to replace the headlamp and dimmer switches, several connectors, and then bypass the wiring in the circuit with new 12ga wire run alongside the original harness. It's supposed to take 1.3 hours for a service technician to do this..."
There is another way to fix this.
'87-'93 GT Fog Lamp & Main Light Switch Fix
Main Light & Fog Lamp Switches - only affects GT's. In the February, 1991 edition of Popular Mechanics, the "Car Clinic" by Mike Allen had the following: Fogged Out Q: "I have a 1988 Ford Mustang GT. After about 20 minutes with my headlights...
www.stangnet.com
F
FastFox21
Porter Tx
Oct 6, 2020
  • Oct 6, 2020
General karthief said:
Check the fuses?
Thanks for the response and yes it is a GT
F
FastFox21
Porter Tx
Oct 6, 2020
  • Oct 6, 2020
Blown88GT said:
GT or LX?
If GT, were the fog lights were on?
www.stangnet.com
GT and it’s a 92
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 9, 2020
  • Oct 9, 2020
@FastFox21
SEE Mustang GT Fog Light Fix to fix the foglight problem. The stock wiring isn't up to the job and is overheating. The headlight switch & turn/multifunction switch are affected by Ford's wiring problem. Sometimes it overheats so badly that the plastic shells of the wiring connectors start to melt. This will show you how to add a relay to the fog lights to relieve the overload on the headlight wiring.
Be careful not to use bulbs rated at more than 55 watt each with the stock fog light wiring. Using oversize bulbs can result in overheating the wiring harness and electrical fires. Definitely do the fog light fix first.
I did mine differently, but I had to build my own wiring harness for the fog lights. This is more trouble than it is worth for most folks. I left all the wiring on the stock light switches in place and used the fog light wiring to power the relay coil. The other side of the relay coil is connected to ground. I have an inline fuse that picks up power from the battery side of the starter solenoid. It is connected to the relay contact. The other relay contact is connected to the new wiring harness I made for the fog lights.
The advantage of making your own foglight wiring harness is that you can run 100 watt fog light bulbs. The stock wiring harness will not use 100 watt bulbs without overloading and causing a fire.
Unless you are good at electrical wiring, have the skills and tools (crimp tool, soldering gun, heat gun for the heat shrink tubing, etc.) I recommend that you stick with the Corral method.
Technical explanation of why the wiring and switches overheat.
You asked for it...
I= Current
E= Voltage
R= Resistance
W= Watts
Two 55 watt fog lamps =110 watts. Find the current in the circuit
I= W/E
110 watts/14 volts = 7.85 amps for fog lights alone.
Since the lighting circuit supplies headlights, taillights, and parking lights, etc.
56 watts 2 each GE Part # L3156 corner light 28 watts each
90 watts 2 each GE Part # 9004 headlight 45/65 watts each (low beam)
63 watts 2 each GE Part # L194 parking light 31.5 watts each
56 watts 2 each GE Part # L3157 tail light 28 watts each
265 watts Total
Total other exterior lighting current
I=W/E
265 watts/14 volts = 18.92 amps
18.92 amps other exterior lighting current
+ 7.85 amps fog light current
26.77 amps with all exterior lights and fog lights on.
The 12 gauge power feed wire to the exterior lighting switch is rated at 20 amps
26.77
- 20.00
6.77 amps excess current
7.85 amps used by fog lights
-6.77 amps excess current
1.08 amps to run the fog lights left if you stay within the 20 amp limit of the wire.
With 1.08 amp of current, the fog lights probably won’t produce any useable light.
Added resistance required to reduce fog light current to permissible 20 amp limit
R=E/I
14 volts/6.77 amps = 2.06 ohms
Resistor wattage
W=EI
14 volts x 6.77 amps = 94.78 watts
You would need a 2 ohm, 100 watt resistor.
Light bulb ratings from http://www.roadparts.com/catalog/section30.pdf
Radio shack resistor catalog - no matches , and no combinations that could be used to make a 100 watt, 2 Ohm resistor.
See RadioShack.com
Ohm’s law – in case you have any questions about my formulas - Ohm's Law Calculators
Reactions: General karthief
Blown88GT
2,283
524
164
Oct 11, 2020
  • Oct 11, 2020
jrichker said:
@FastFox21
Your link to the Corral is no good anymore.
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
