No Oil Pressure While Cranking
  • Thread starter Thread starter gnx547
  • Start date Start date Jun 6, 2015
gnx547
283
  • Jun 6, 2015
I disabled the fuel & ign and I cranked the motor for a few secs to build oil pressure through the engine. While cranking the oil pressure needle did not move at all. I checked to make sure the oil sending unit is plugged in and it is. I removed the sending unit and oil did come out, so I know there is some pressure. I hooked up an oil pressure gauge and cranked the motor for a few secs there is no pressure reading on the gauge. I removed the distributor and spun the drive shaft with my drill and I have oil pressure reading on the gauge. Why is it that I don't have any pressure reading on the gauge when I'm cranking the motor? Any ideas?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Jun 6, 2015
  • Jun 6, 2015
bad sending unit
Reactions: Grabbin' Asphalt
Jared Hess
76
9
18
Six Mile Run, PA
Jun 6, 2015
  • Jun 6, 2015
Maybe your dizzy or shaft is stripped. Does it seem as long as it should be possible it snapped up high?
gnx547
283
  • Jun 6, 2015
I looked both at the dist and the oil shaft and both are not stripped and it didn't snap off
Jared Hess
76
9
18
Six Mile Run, PA
Jun 6, 2015
  • Jun 6, 2015
Never seen the inside of a pump but maybe a problem there is the only other thing or a possible air bubble that you got out with the drill if that could happen have you tried putting it back together now that you got pressure with the drill.
Jared Hess
76
9
18
Six Mile Run, PA
Jun 6, 2015
  • Jun 6, 2015
If not I would try the drill and make sure you got pressure with it then put it back together and give it a whirl. That's an odd situation.
Jared Hess
76
9
18
Six Mile Run, PA
Jun 6, 2015
  • Jun 6, 2015
Just thought about and it might be a stupid question but you did check the oil level right? Lol
  • dan50
  • Jul 18, 2026
dan50
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
D
Engine Question about oil pressure gauge
  • dqureshi06
  • Dec 30, 2024
Fox 5.0 Mustang Tech Dec 31, 2024
General karthief
