  • SN95 4.6L Mustang Tech
NO SPARK????
  • Thread starter Thread starter brent_cosenza
  • Start date Start date Apr 11, 2007
brent_cosenza
70
Georgia
Apr 11, 2007
  • Apr 11, 2007
I cant figure out why my car has no spark none of the COP's are firing...i have the alternator unhooked the crank sensor and cam sensors are new as well as the ECU... oh i unhooked the alternator becaused it burned up and i need a new one and all the fuses are good so anyone else got any ideas the car has a new computer in it i just paid 175 for it from prestige mustang can anyone give me some advice?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Apr 11, 2007
  • Apr 11, 2007
Is the PATS light flashing?
With a new ECU I am pretty sure a Ford dealer needs to get involved to get that thing running due to some kind of PATS security code or something
You changed out a lot of stuff. How do you know it is all installed correctly? Who did the work? Can you get it to an AutoZone to have the alt, bat, and charge system checked for free in the parking lot?
brent_cosenza
70
Georgia
Apr 11, 2007
  • Apr 11, 2007
ok the PATS Light did flash but I've had all that reflashed but i know its all installed correctly because im a mechanic and my friend is a tech at the local ford company and we did the work...
brent_cosenza
70
Georgia
Apr 16, 2007
  • Apr 16, 2007
no one has any ideas as to why i have no spark all my fuses are good and so is my crank sensor
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 16, 2007
  • Apr 16, 2007
is the crank trigger wheel ok? make sure you have the proper gap between the crank sensor and the teeth of the trigger wheel
Mike97gt
it doe snot
10,633
Apr 16, 2007
  • Apr 16, 2007
Check continuity from pcm pin 21 to pin 2 of the crank pos sensor harness side also check pin 22 pcm to pin 1 of the crank pos sensor harness side
Also check ground G201 this is the shield for the CKP circuit this ground is located near the PCM in the right side kick panel. also check splice s143 and s165 under the hood near the right rear of the engine compartment and splice S204 ( more likely culprit) in the LH kick panel.
but first check for continuity this is a way more likely cause
brent_cosenza
70
Georgia
Apr 16, 2007
  • Apr 16, 2007
my car is a 2002 GT svttech and it'll take me a while to check all of this thanks for the advice anyone got anything to add.
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • dan50
  • Jul 18, 2026
dan50
  • Gulftown980x
  • Jul 29, 2026
squeak93
P
Electrical 2001 GT Overcharging
  • PseudoGT
  • Dec 3, 2025
SN95 4.6L Mustang Tech Dec 13, 2025
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
