  • 1994 - 1995 Specific Tech
no strut tower brace
  • Thread starter Thread starter RFMustangGT
  • Start date Start date Aug 30, 2005
RFMustangGT
294
Knoxville,TN
Aug 30, 2005
  • Aug 30, 2005
could driving without your strut tower brace for a long time, hurt the front end? I've been driving withoutone since last december and my front is so bad. it drifts to the right and is really loose. also when driving the steering wheel shakes like you have just pushed the brakes with warped rotors. is something really messed up here?
95riosnake
630
Pittsburgh, PA
Aug 30, 2005
  • Aug 30, 2005
well cobras didn't even come with one. So I don't know if it's necessary to have one. I haven't heard of cobras having any extra bracing to make up for the lack of a STB either, so I would say the cornering under hard driving might be less tight, but I wouldn't think it would damage anything.
Engel
219
Currently Fort Walton Beach
Aug 30, 2005
  • Aug 30, 2005
Theres a huge debate whether or not strut tower braces do anything in the first place, alot of people leave them off.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Aug 30, 2005
  • Aug 30, 2005
I personally believe that anything you can do to stiffen things up is a benefit, but that doesnt mean it's harmful to drive without it.
RC
RFMustangGT
294
Knoxville,TN
Aug 30, 2005
  • Aug 30, 2005
I thought cobra had something different in the K-member?
I guess my front is just shot then. grrr. if it's not one thing it's another. I need to sell my car cause the front suspension is going, I think the transmission is starting to slip, rear end is making funny sounds. damn, so much at the same time.
95WhiteVenom
624
Alabama
Aug 30, 2005
  • Aug 30, 2005
Wont hurt to have that thing off. Really doesnt do a lot anyway unless autoX'ing. The wondering may be that you need a front end allignment. Unless something feels worse when breaking and your having to fight the wheel then it maybe the rotors.
BlackVert
5,589
9
98
Bethesda, MD
Aug 30, 2005
  • Aug 30, 2005
i drove without one on mine for over a year and i did not know what i was missing. when i put mine on, it really cleaned up the ride, MUCH less wobbly, more sure footed, and it doesn't bottom out as much with the 2" drop springs i have. for me, there is no debate at all, the stb makes for a much better ride.
then again, i have a convertible.
check this thread
http://eleanor.pro3i.com/showthread.php?t=563841
your problem sounds like an alignment problem tho. at least that is what i am hoping! i have the same problem. are your tires wearing unevenly?
i tried to get an alignment, but the 2" drop made it impossible to get it right (i have stock c/c plates), which is why i an going to coil-overs. then i can adjust the ride height, get the alignment right, and fix the problem of scraping on speed bumps and such.
95riosnake
630
Pittsburgh, PA
Aug 30, 2005
  • Aug 30, 2005
yea, front end alignment will make your car go all over the place if its not right.
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Aug 30, 2005
  • Aug 30, 2005
Sounds like you need an alignment, no biggie.
Also, a transmission rebuild isn't that bad and neither should having the rear end rebuilt. Gotta remember these are 10-11 year old cars and they're gonna start having problems, just fix em before they get worse and more costly.
GRGT1994
1,034
#10
  • Aug 30, 2005
  • #10
Balance your tires too.
tomustang
Psychotic Member
3,434
McLean Hospital
Aug 31, 2005
#11
  • Aug 31, 2005
  • #11
Same as a K-member brace, you'll only notice it durring hard cornering.
RFMustangGT - It sounds like you have an alignment issue, or something is wrong with your braking.
1slow95
1,797
ohio
Aug 31, 2005
#12
  • Aug 31, 2005
  • #12
That's what I was thinking. Your tires are probably out of balance, or need replaced. An alignment will also help.
My old '88 V-6 Cougar felt like the rear end was moving around when cornering. I thought the bushings were shot, but I put new tires on it and it felt like a new car.
RFMustangGT
294
Knoxville,TN
Aug 31, 2005
#13
  • Aug 31, 2005
  • #13
they are brand neew tires so I'm not sure if I can see any wear patteren yet. I'm going to start calling today to find someone to fix it. I still think my tranny is starting to go as well cause today it was really have some issues grabbing into gear and driving down the road it feels like it misses.
I
Indy Mike
14
Leeds Alabama
Aug 27, 2006
#14
  • Aug 27, 2006
  • #14
I read somewhere about a frame bushings causing a shake I get a shake from 45 to 55 and is not the tires going to replace bushings latter today. I think the strut tower brace was optional some have it some do not.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 27, 2006
#15
  • Aug 27, 2006
  • #15
My car drifts to the right, but it's in the caster, which is not adjustable w/o CC plates. So I am screwed until I get them.
Foxes don't even have a STB btw.
You might want to check out your shocks/springs/bushings and see if anything is screwy.
Scott
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
