  • SN95 4.6L Mustang Tech
non-pi heads and pi cam question
  • Thread starter Thread starter juecke98gt
  • Start date Start date Jun 4, 2008
J
juecke98gt
Banned
May 31, 2008
78
  • Jun 4, 2008
Is the pi-cam a direct replacement with the non-pi cam, or do i need something special to do the swap. Thanks
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Jun 4, 2008
  • Jun 4, 2008
all you need is pi cams bolts 5-10$, the guy at the local junk yard gave them to me
J
juecke98gt
Banned
May 31, 2008
78
  • Jun 4, 2008
Sweet thanks
98COBRA281
1,348
30
59
Jun 4, 2008
  • Jun 4, 2008
no prob the pi cams bolts are accually smaller then npi cam bolts pi cam bolts are 10mm, npi are 12mm
J
juecke98gt
Banned
May 31, 2008
78
  • Jun 4, 2008
Quick question when you say camshaft bolt where are these bolts exactly. I know there are cap cluster bolts on top that hold the cam in place is this what your talking about?
98COBRA281
1,348
30
59
Jun 4, 2008
  • Jun 4, 2008
the bolts that holds the cam gears on the camshafts, there is only 2 of them i have some pics of my motor apart when i was doing the cams, if you want to see them ill post them for you.
98COBRA281
1,348
30
59
Jun 4, 2008
  • Jun 4, 2008
here you go, circled in red
J
juecke98gt
Banned
May 31, 2008
78
  • Jun 4, 2008
Thanks alot big help !! Im swapping with some new ported and polished non-pi heads and pi cams with a performance intake in a couple weeks. Thanks again
J
juecke98gt
Banned
May 31, 2008
78
  • Jun 4, 2008
By tha way your engine looks super clean nice !!!
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Jun 5, 2008
#10
  • Jun 5, 2008
  • #10
new alternator
98COBRA281
1,348
30
59
Jun 5, 2008
#11
  • Jun 5, 2008
  • #11
thanks, you should see it now, i polished alot of things like the iac, egr, and most of the bolts
Winters98GT said:
new alternator
its about 2 years old
d98gt
4,505
59
204
SE Texas
Jun 5, 2008
#12
  • Jun 5, 2008
  • #12
There are a few writeups about the swap and I am thinking about doing it soon!! I have the parts for the cams, just need to pick up gaskets and some hose for the intake swap
http://www.moddedmustangs.com/forums/96-98/21676-cam-swap-sohc-4-6-1998-gt.html
http://www.moddedmustangs.com/forums/npi-to-pi-intake-swap-vt1878.html
http://www.mustangforums.com/m_3833004/tm.htm
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Valve hitting piston?
  • krazedstang
  • Jun 9, 2025
SN95 4.6L Mustang Tech Jun 12, 2025
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
