O/R Pipe Checklist
  • Thread starter Thread starter mustanggt5pt0
  • Start date Start date Mar 19, 2007
mustanggt5pt0
34
Cedar Falls, Iowa
Mar 19, 2007
  • Mar 19, 2007
When I go to put my engine back together im bolting up a new catless H-pipe and am just wanting to make sure I have all my bases covered. From what I have read in past threads I have the following to be aware of:
1. Plugging air tube on the pipe itself
2. Plugging holes on the back of the heads
And as for the wires connected to the air tube to the smog pump? Let them hang? Will it set some codes off?
Obviously wont need that tube from the smog pump to the air tube connected to the h-pipe so I'll just let the pump act as a pulley...will letting it pump air into nothing cause any codes?
HISSIN50
34
129
Mar 19, 2007
  • Mar 19, 2007
You can also just connect the smog tube to the O/R pipe (if you ever envision hooking back up to cats in the future, it's not a bad idea).
From what I recall, some folks don't get a code with disconnected TAB/TAD's and some do. Resistors can trick the the computer's CEL.
The pump can discharge to atmosphere - that's no biggie. You might want to watch how this is done just to keep the head of the pump from becoming corroded or dirty.
Good luck.
U2SLO450
118
  • Mar 19, 2007
so are you saying the new h pipe doesn't have the air tube hookup? If not just buy a shorter belt and bypass the smog pump
mustanggt5pt0
34
Cedar Falls, Iowa
Mar 19, 2007
  • Mar 19, 2007
No its a MAC pipe and has the airtube hookup.
bobbyd
312
San Antonio/Los Angeles
May 16, 2007
  • May 16, 2007
Good luck.
what would happen if i remove that smog tube? what will i need to do? put somethiong in the h pipe where it goes to and one in the hose? if i dont close them will the smog be all over the plase under the hood?
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
C
Engine Code 94 and 13
  • CmdrDerp
  • Nov 3, 2024
Fox 5.0 Mustang Tech Nov 4, 2024
AeroCoupe
