Off road Mac H pipe?
  • Thread starter Thread starter CPB00GT
  • Start date Start date Feb 13, 2004
C
CPB00GT
531
Florida
Feb 13, 2004
  • Feb 13, 2004
The off road pipe I had for my 5.0 did not fit, it was my fault. I am picking up a Mac off road H pipe today. Does it have the opening for the smog pump tube or not? If so, I had to hacksaw my tube to get the stock piece off. I guess I could rig the tube together for now when I install the new pipe today or does anybody have a suggestion? I know I could delete the whole smog pump but need to know the parts I will need cause I am going to complete this project once and for all later today.
91lxvert
110
  • Feb 13, 2004
the mac offroad h has provisions for the smog pump tube
93VertLX
667
Dayton, OH
Feb 13, 2004
  • Feb 13, 2004
Yep it has the opening for the smog tube. Some careless person has removed my smog pump!
C
CPB00GT
531
Florida
Feb 13, 2004
  • Feb 13, 2004
I am glad to know that the Mac has the smog pump pipe provision. Now which way should I go today? Rig my hacksawed tube together or tell me what I need to remove it all?
QUICK91LX
968
New Jersey
Feb 13, 2004
  • Feb 13, 2004
the mac off road h is a good pipe, i had one on my 91 LX...as for your smog pump tube, if you think you can rig it together and seal it up well then go for it, otherwise hit up your local parts store or ford dealer and get a new one...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 13, 2004
  • Feb 13, 2004
Here’s some help (a bit late in your case) for removing the air tube from the H pipe...
Try removing the bolts from the upper mounting bracket at the rear of the engine, and then loosen the clamp on the air tube by the cats. Then get a BIG pair of ViseGrip pliers (you really didn't hear me say that), clamp down hard on the tube about 1 1/2" from the clamp and pound away on the ViseGrips. It will come off if you keep at it.
In really stubborn cases, drill a 1/8" hole all the way thru the air tube 1 1/2" from the clamp, put a nail, pin punch or whatever in the hole, seat the ViseGrips up against the nail or pin punch and pound away on the ViseGrips. This is a better method, as you can do the same thing in reverse to put the old tube back on, with some clever means to cover or fill the hole (weld, braze, sheet metal screws, hose clamps and hi temp hose, etc.).
A replacement air tube cost me $44 plus the air valve didn't come with it - another $17, so reuse when and where possible if your money is limited.
BYRDPE
1,556
Memphis,Tn.
Feb 13, 2004
  • Feb 13, 2004
Just get a peice of rubber heater hose to make your connection.
You will be fine.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Feb 13, 2004
  • Feb 13, 2004
You will be fine.
L
Exhaust 95 gt pypes catted x pipe
  • Lx5.0fiend
  • Aug 22, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Sep 18, 2025
revhead347
J
O2 sens
  • JJ's90fox
  • Sep 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2025
Mustang5L5
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
WTB/Trade Off road exhaust H pipe for 86 -98
  • Canyonred86
  • Jan 7, 2025
  • Other Classifieds
Other Classifieds Jan 17, 2025
89ripper
I
Engine What Aluminum Heads???
  • Iceman1998
  • Sep 8, 2024
2K
Fox 5.0 Mustang Tech Sep 15, 2024
