  • SN95 4.6L Mustang Tech
Oil Leak!
  • Thread starter Thread starter Numbnuts
  • Start date Start date Oct 24, 2012
N
Numbnuts
  • Oct 24, 2012
Anybody point me in the direction of a post that goes thru the repair of an oil leak from the gasket on the filter adapter on my 4.6? Thanks, NN
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 25, 2012
  • Oct 25, 2012
FWIIW, it's easy. Just drain the oil and coolant. Remove the oil filter. Disconnect the oil sending electrical connector. Remove the bolts. If you have an oil cooler, it will be necessary to separate the two halves.
If you still need more information, the Ford service DVD is for you. If interested in getting a copy for yourself I maybe able to help. PM if interested.
N
Numbnuts
  • Oct 26, 2012
If I dont have a coolant hose on the adapter itself (no oil cooler), do I still need to drain the antifreeze?
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 26, 2012
  • Oct 26, 2012
No you don't need to drain the coolant if you don't care about making a mess. But the coolant will run out anyway when the adapter is removed. However, now there's a greater chance that the coolant will get into the oil.
N
Numbnuts
  • Oct 27, 2012
There are conflicting reports on this between the 2V & 4V motors. From what Ive been told the 2V motors do not have an external oil cooler where the 4V does. I am going to drain the coolant reguardless. Im not taking the chance. Ill report back once its done for others to fall back on.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 28, 2012
  • Oct 28, 2012
Note, for those of you with a Mustang oil cooler, if you look at it CLOSELY you will discover that the oil cooler is actually a part bolted onto the oil filter adapter. Sooooooo when the large Allen bolt through the center is removed, what remains is a similar oil filter adapter that is on every Romeo block (no coolant hose nipple).
Note, for the external oil filter adapter it's necessary to separate the two halves (remove the large Allen bolt) to get access to bolts that hold the block to oil adapter on.
If trying to be technically correct, some 2V motor did come with an external oil cooler. My 96 GT had one. Later MY 2V GT Mustangs did not have an oil cooler.
But in terms of replacing the oil filter adapter block gasket, the procedure is mostly the same. If your motor has an oil cooler, then separate the halves by removing the Allen bolt. Then proceed as normal.
N
Numbnuts
  • Oct 28, 2012
This is fact. Although my '01 does not have an external oil cooler, the oil filter adapter bracket DOES house both the oil feed & return lines as well as the feed to the bottom radiator hose back to the radiator. I did drain the coolant from the rad drain on the right front bottom as well as remove the lower rad hose from the radiator itself. Although there was an additional drain port just below the adapter bracket on the block that could be used, a small amount of coolant escaped when I removed the bracket itself. Not a huge mess. Upon inspection of the surfaces I noticed some mild corrosion into the bracket housing itself. I think due to the collant pooling up at the gasket, it ate away some of the material of the bracket. I am in the process of filling the voids with JB Weld, letting it dry & sanding to flush. I am planning on using the stock replacement gasket (FelPro $15) from any auto parts store, but I did pickup & custom cut a couple extra rubberized paper gasket material gaskets as a backup if this fails, with some copper spray gasket to seal it up. Not planning on doing this twice, but we'll see how it goes.
N
Numbnuts
  • Nov 3, 2012
Back together & so far so good.
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Monday at 4:43 AM
manicmechanic007
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
