Oil Leak
  • Thread starter Thread starter Lens88fox
  • Start date Start date Aug 10, 2017
Lens88fox
24
Canada
Aug 10, 2017
  • Aug 10, 2017
Hello guys I have a 1990 mustang lx with a 460 cui big block I have a very small oil leak not sure where its from just had an oil leak from the pan fixed but this one looks like it might from the rear main seal, I moved back to my parents house after my dad passed away in dec and I have no way of doing this work myself anymore since I have no garage, does anybody know a reputable repair shop in and around Cambridge Ontario or if this even worth me fixing as the leak is very small and Ive been told it will just start leaking again.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Aug 10, 2017
  • Aug 10, 2017
spray down the engine and undercarraige with some purple power
where you think the enfgine may be leaking spray some aerosol foot powder
the leak will turn the area black from white
also put a piece of cardboard under the front of the car where you park
when you move the car you will see where the drips are and can help pinpoint it
If it is the rear main seal on these cars, they are notorious for leaking, On your 460, it could be either a one or two piece.
No one can answer if you should fix it without knowing where the leak is from other than to say in general yes you should repair it
Reactions: Lens88fox
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Aug 10, 2017
  • Aug 10, 2017
To be honest, with an old pushrod engine, you just kind of have to accept the oil leaks. Be lucky you have a Ford. There are like 10 million small block Chevys still running, and only 5 of them don't leak oil.
Kurt
Reactions: mikestang63, General karthief and Lens88fox
Lens88fox
24
Canada
Aug 10, 2017
  • Aug 10, 2017
Kurt
Thanks I kind of figured as much i really laughed at this one, I was also told to live with the leaks the 460cui is from 1978 so your probably right
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Oil leaking
  • greenflash79
  • Apr 1, 2026
  • 2007 - 2014 Shelby GT500 Tech
2007 - 2014 Shelby GT500 Tech Apr 6, 2026
greenflash79
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
