Oil level sensor fitting seeping oil
  • Thread starter Thread starter tjm73
  • Start date Start date Nov 5, 2004
T
tjm73
2,418
Rush, NY
Nov 5, 2004
  • Nov 5, 2004
Anyone else having/had this problem? Do I simple need a new gasket or something?
It's not hardly any oil, but it bothers me just the same.
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
Nov 5, 2004
  • Nov 5, 2004
Next time you change oil and it is drained, loosen the fitting so there is some space in the outside rim, wipe the oil away and squeeze some RTV into the crack around the outside. Then tighten back and it will never bother you again.
Are you running synthetic or thin oil? It tends to find ways out of an engine that thicker oils dont.
T
tjm73
2,418
Rush, NY
Nov 5, 2004
  • Nov 5, 2004
Nope, I run 20-50 Valvoline Racing oil.
HISSIN50
34
129
Nov 5, 2004
  • Nov 5, 2004
sometimes the sensors come apart too much to fix. new ones are not that pricey (or just plug it). The Shape went through this recently and had to plug his, as i recall.
good luck.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
