  • SN95 4.6L Mustang Tech
Oil Pan
  • Thread starter Thread starter IJUSTWON
  • Start date Start date Aug 11, 2004
I
IJUSTWON
242
  • Aug 11, 2004
How hard is it to replace the factory oil pan on my 2001 mustang gt? I knocked a whole in it and need to put my new one on.
mogs01gt
3,113
30
119
Ohio
Aug 11, 2004
  • Aug 11, 2004
you knocked a hole in it??
I
IJUSTWON
242
  • Aug 11, 2004
Ran over something in the road.
mogs01gt
3,113
30
119
Ohio
Aug 11, 2004
  • Aug 11, 2004
Holy **** man, you do not have very good luck with your car. You will have to remove the K member or take the motor out. Im not sure if you can slide it out with the K member in place but I wouldnt think that is a good idea.
J
Jake795
110
  • Aug 11, 2004
i just replaced mine. Get the FRPP pan if possible. It's $33 vs. around $100 for the OEM pan. I beleive you just have to jack the motor up a few inches if you planning on just changing the pan. When i dented mine i went ahead and pulled the engine and swapped heads and installed long tube headers. It was actually a lot more work than i wanted to do. I suggest just changing the pan and you'll be rolling again in no time.
Jake
I
IJUSTWON
242
  • Aug 11, 2004
All i want is to Put my replacement pan on, how hard of a job would that be and could i jus go under and unbolt and slide it out?
I
IJUSTWON
242
  • Aug 11, 2004
I
IJUSTWON
242
  • Aug 11, 2004
J
Jake795
110
  • Aug 11, 2004
no you can't just go under and slide it out. it has a slight front sum that prevents this from happening. Therefore you either have to drop the k-member down or raise the engine about 4 inches.
Jake
I
IJUSTWON
242
#10
  • Aug 11, 2004
  • #10
How hard is it to drop the K-member?
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
Mustang 2 74’ Oil Pan Help
  • scaryfresh
  • Aug 12, 2026
1974 - 1978 Mustang II Talk & Tech Aug 12, 2026
LILCBRA
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
Engine What’s that?
  • PonyGTrider
  • Aug 24, 2026
Fox 5.0 Mustang Tech Aug 25, 2026
PonyGTrider
W
Dipstick
  • wccurtis1963
  • Jun 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
Willybill32
