Oil Pressure Dropping Help!!!
  • Thread starter Thread starter smitty194
  • Start date Start date Jul 10, 2012
1 of 2 Next Last
smitty194
15
  • Jul 10, 2012
When I stop at light or stop sign , oil pressure drops to zero pressure an car cuts off , when driving oil pressure run normal, when i stop an oil pressure drop if i press throttle it rises to normal , does any have an idea Wat is causing this
MFE92
1,094
373
124
Phoenix
Jul 10, 2012
  • Jul 10, 2012
It sounds like you think the low oil pressure is causing the engine to die, but it's far more likely that it's the other way around. Something is probably causing it to stumble and die at idle, and when that happens, the RPM drops so low that the oil pressure drops below the 10-12 psi necessary to make the stock needle show pressure.
Reactions: Tsixe
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 10, 2012
  • Jul 10, 2012
Need more info, is the engine a rebuild? How old is the oil pump? how much pressure do you have running it down the road?
I ask because i have seen the sending unit go bad and send a false reading to the gauge, but you say the car cuts out... does it die abruptly or sputter and die?
does the car have oil pressure when you first start it in the morning?
Reactions: Tsixe
smitty194
15
  • Jul 10, 2012
Motor is stock303 cam , good pressure in the am , it only cuts off when press clutch to stop , it don't do it all the time tho , sometimes wen I stop everything is normal
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 10, 2012
  • Jul 10, 2012
which 303 cam? b, e, f, x....ect. i would say it has nothing to do with your oil pressure. your pressure is dropping due to the engine stalling. Once again does the car jerk around or does it just die as you roll to a stop?
ID89GT
1,659
18
49
Spokane Valley, WA
Jul 10, 2012
  • Jul 10, 2012
Put a mechanical gauge on it, also would check the oil level itself just to rule it out.
smitty194
15
  • Jul 10, 2012
E 303 cam , car doesnt jerk or sputter just simply cuts off, nice an gently cuts off lol when car is not cutting off it will idle smooth rpm stays steady in one spot, but sometimes it just simply cuts off when I stop
a91what
SendMeUrDataLog
10,733
6,716
214
Hillsborough county
Jul 10, 2012
  • Jul 10, 2012
suspect the IAC or VSS probably the iac... it controls the idle of the car.
smitty194
15
  • Jul 10, 2012
Iac is brand New replaced it less than 300 miles ago , I just researched vss issues an some people were having same problem as me , I will get one with in the next two days an let you if it solved problem , thanks for your help
YLWSTANG
42
Mass
Jul 11, 2012
#10
  • Jul 11, 2012
  • #10
I had the same issue last week on my car it ran nice no problems just would shut off. I checked my base idle and brought it up to 800 no more issues.
Admin Dude
Jan 4, 1985
43,535
21,705
234
Box behind Walmart
Jul 11, 2012
#11
  • Jul 11, 2012
  • #11
Just wanted to comment that being brand new doesn't mean anything. It can be junk, right out of the box.
That said, with what little information you've posted, I would suspect a wiring/maf problem or vacuum leak is causing your car to stall.
Pull codes and see if anything pops up.
smitty194
15
#12
  • Jul 11, 2012
  • #12
K , will see if any codes come up , my gut instinct has be telling me is vac leak or maf
YLWSTANG
42
Mass
Jul 11, 2012
#13
  • Jul 11, 2012
  • #13
A vacuum leak is easy to find put a hose onto the capped port on the firewall tree light a cigar and start blowing smoke in. Eventually you'll see smoke come out the air filter hopefully somewhere else before that, if there is a vacuum leak.
Reactions: Tsixe
tca7291
I can see your wieners.
5 Year Member
Sep 1, 2011
1,801
152
143
Raleigh, NC
Jul 11, 2012
#14
  • Jul 11, 2012
  • #14
^ That sounds like a fun trick! Remember to pop a beer with your cigar!
MFE92
1,094
373
124
Phoenix
Jul 11, 2012
#15
  • Jul 11, 2012
  • #15
LOL WUT
Vacuum leaks don't leak air OUT of the system, they leak it IN.
Admin Dude
Jan 4, 1985
43,535
21,705
234
Box behind Walmart
Jul 11, 2012
#16
  • Jul 11, 2012
  • #16
MFE92 said:
LOL WUT
I think he means with the motor off, blow smoke in through vacuum tree through a hose. That would work great if that were the only place you could get a vac leak at.
(I sure hope MFE sees this before he heads out the car running in the garage with a cigar and garden hose)
MFE92
1,094
373
124
Phoenix
Jul 11, 2012
#17
  • Jul 11, 2012
  • #17
:facepalm:
I thought he meant with the engine running
smitty194
15
#18
  • Jul 11, 2012
  • #18
Yea was hoping he was talking bout doing that with car off lol I'm off Fri so I will try to solve the problems an let yall no Wat the solution was
YLWSTANG
42
Mass
Jul 11, 2012
#19
  • Jul 11, 2012
  • #19
MFE92 said:
:facepalm:
Lol, definately with the motor off, I've done plenty of stupid things. You should meet the wife.
YLWSTANG
42
Mass
Jul 11, 2012
#20
  • Jul 11, 2012
  • #20
The firewall tree is attached to the intake so the smoke goes through the whole intake. It does work better if you block the throttle body with duct tape.
1 of 2 Next Last
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
