Oil Pressure Gauge Doesn't Work
  • Thread starter Thread starter MVG•GT93
  • Start date Start date Dec 14, 2015
1 of 2 Next Last
MVG•GT93
Active User
Mar 17, 2014
40
Dec 14, 2015
  • Dec 14, 2015
Oil pressure gauge isn't reading anything. It hasn't moved since I got the car started again. How can I diagnose the problem?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 14, 2015
  • Dec 14, 2015
Take the wire off the sender, and ground it. It should peg the gauge if the gauge and wiring are correct.
MVG•GT93
Active User
Mar 17, 2014
40
Dec 14, 2015
  • Dec 14, 2015
With the car started or off?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 14, 2015
  • Dec 14, 2015
It should work with the car off, but key in the run position.
MVG•GT93
Active User
Mar 17, 2014
40
Dec 14, 2015
  • Dec 14, 2015
Ok it worked
Reactions: liljoe07
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 14, 2015
  • Dec 14, 2015
If the gauge worked, then you just need to replace the oil pressure sender that is screwed into the side of the oil pressure port extension.
MVG•GT93
Active User
Mar 17, 2014
40
Dec 14, 2015
  • Dec 14, 2015
That's what I thought thanks so much for the help my friend!
Reactions: liljoe07
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 14, 2015
  • Dec 14, 2015
Any time!
MVG•GT93
Active User
Mar 17, 2014
40
Dec 14, 2015
  • Dec 14, 2015
I put the new one in and the guage doesn't move when I start it now
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 14, 2015
#10
  • Dec 14, 2015
  • #10
Are you sure you getting a good connection on the sender? What was the part number of the sender? Is this for the 93 foxbody?
MVG•GT93
Active User
Mar 17, 2014
40
Dec 14, 2015
#11
  • Dec 14, 2015
  • #11
Yes it's for the 93 foxbody but I just dropped in a 94 cobra motor. Took out the old sender and went and picked one up from O'Reillys and looks the same. How would I know if I'm getting a good connection? I think the part number is 2-8141
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 14, 2015
#12
  • Dec 14, 2015
  • #12
Just make sure the connection is real tight where the sending wire connects to the sender. Do you have a volt meter?
MVG•GT93
Active User
Mar 17, 2014
40
Dec 14, 2015
#13
  • Dec 14, 2015
  • #13
Just took off my valve cover on the driver side to see if I'm getting oil and its practically dry. So I turned it over let it run for a second and still no oil. So I think I have no oil pressure.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 14, 2015
#14
  • Dec 14, 2015
  • #14
Well that's not good. I assumed at first that the engine had already been ran. Does it have oil in it? Not trying to insult you, but happens sometimes.
MVG•GT93
Active User
Mar 17, 2014
40
Dec 14, 2015
#15
  • Dec 14, 2015
  • #15
I understand. It's definitely got oil. The motor hasn't ran for a couple months. It's out of a 94 cobra and the motor was built by summit. I took out the distributor to prime the oil pump and that little key that goes to the center of the distributor is gone. Was there last night when I put the new distributor in.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 14, 2015
#16
  • Dec 14, 2015
  • #16
Key? You mean oil pump shaft?
MVG•GT93
Active User
Mar 17, 2014
40
Dec 14, 2015
#17
  • Dec 14, 2015
  • #17
Yeah the oil pump shaft sorry
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 14, 2015
#18
  • Dec 14, 2015
  • #18
That sucks, its in the oil pan! And thats your oil pressure issue.
MVG•GT93
Active User
Mar 17, 2014
40
Dec 14, 2015
#19
  • Dec 14, 2015
  • #19
So I gotta drop the oil pan and order the ARP driveshaft? Is it broke or did it just fall in there and I can just put it back without getting a new one. Or do u recommend I order the ARP?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Dec 14, 2015
#20
  • Dec 14, 2015
  • #20
Someone probably installed the shaft from the top. So when the distributor was removed, it came out of the pump and into the pan. The shaft is supposed to be installed from the bottom when the oil pump is put it. There is a retainer clip that keeps the shaft from being pulled out of the pump whenever the distributor is removed. ARP shaft is a nice investment.
Reactions: MVG•GT93
1 of 2 Next Last
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
