Oil Pressure Going NUTS
  • Thread starter Thread starter MikeROD16
  • Start date Start date Jul 1, 2008
MikeROD16
Miami, FL
Jul 1, 2008
  • Jul 1, 2008
Ok, so i changed the oil on my car not too long ago. But when I turn on the car, the oil pressure is normal and within a few moments, itll start shooting up and down the whole gauge like some crazy guy on crack. It really bothers me cuz you can hear it hitting the top and bottom of the gauge. I changed the Oil Pressure Sensor hoping it would fix things but it didnt. Is it that i put too much oil or what?
Dino Dino Bambino
1,673
90
79
Cyprus
Jul 1, 2008
  • Jul 1, 2008
It sounds like the oil pressure gauge itself may be faulty. The only way to find out is to hook up a mechanical gauge and see if the oil pressure really does fluctuate. If it does, the problem is a sticking oil pressure relief valve inside the oil pump and the cure is a new pump.
ninety15.0
1,336
  • Jul 1, 2008
well how much oil did you put in? That would answer that question pretty quickly? Did you take 5 quarts out? Did you put 5 quarts in?
I would get a nice mechanical OP gauge on there and see what the deal really is.
monte87
876
18
49
new york
Jul 1, 2008
  • Jul 1, 2008
Sounds like the bad wiring, grounding out someplace. i would check the wire going to the sensor and replace it. Myabe the plastic/rubber sheath has scraped off someplace and it hitting the block or some type of metal-causing intermittent fluctuating readings.
Later-Good luck, Ant
Dino Dino Bambino
1,673
90
79
Cyprus
Jul 1, 2008
  • Jul 1, 2008
Unless it's intermittent, grounded out wiring will cause the gauge to stay pegged to the right on high.
btsclan
64
Seattle, WA
Jul 1, 2008
  • Jul 1, 2008
When you changed your oil, did you use an engine flush or just a straight change? I know sometimes when you use an engine flush additive before you drain it, the engine flush can dislodge a peice of gasket somewhere in the engine. If that happened it might of gotten caught in the oil pump and or oil pump screen. Its either something like that or a bad gauge, but I would say that its something to do internally with the engine since the problem only began after you changed the oil.
MikeROD16
Miami, FL
Jul 1, 2008
  • Jul 1, 2008
well, i put 5 quarts in. idk how much came out. but yeah, i actually bought an engine flush the other week, im going to flush it and replace the oil again when i get the rocker arm tightened again. got loose on me
5.0W/5.0
129
Carson Valley, NV
Apr 8, 2010
  • Apr 8, 2010
Oil Presure question
So, on my way to work today, I noticed my oil presure was at zero. I have not been paying much attention to it lately, since I did the efan swap, so I have been monitoring my coolant and batt. gauge more than my speedo. As soon as I noticed it, I did not hear or feel anything different with the car. I drove it another 10 miles without any issues, no spike in the coolent temps or anything. Checked the oil with it running, and with it off and seamed ok. I just changed the oil, and I am running 5-30. When I changed it, it was about a quart low, and was very think, I would say at least straight 30W.
Any ideas?
TenorPlayinGuy
1,208
Canyon Country, Ca
Apr 8, 2010
  • Apr 8, 2010
Replace the gauge in the cluster. I believe that whole side can be removed/replaced.
rd
3,316
63
109
Ocean Springs MS
Apr 8, 2010
#10
  • Apr 8, 2010
  • #10
X2 on the gage. This happened on my 79 once. Drove me nuts. Ran fine, did not make death noises. Put a mechanical gage in and it was fine.
Changed the stock gage, and fixed it. A plastic part of the gage had cracked allowing the wire to move and bounce the needle around.
90_Red_LX
668
Asheboro, NC
Apr 8, 2010
#11
  • Apr 8, 2010
  • #11
I'd put money on a faulty gauge also. A simple oil change is pretty much impossible to screw up if your 10% mechanically inclined, and would be very unlikely to cause y our issue.
281pony
2,681
Oly, WA
Apr 9, 2010
#12
  • Apr 9, 2010
  • #12
the very first thing i do to alll my mustangs is an oil pressure and temp gauge. they are easy to install and pretty cheap. i think for about $100 you can get a pod and both gauges.
very useful for everyday driving..
5.0W/5.0
129
Carson Valley, NV
Apr 9, 2010
#13
  • Apr 9, 2010
  • #13
Thanks for the info guys! I didn't hear the death noises like you said. I was thinking of doing a sn95 interior swap in the future and still might, but I was also thinking of getting rid of the stock guages and going completely aftermarket. I really like the equous gauges and may just do the oil and temp like you said...
5.0W/5.0
129
Carson Valley, NV
Apr 9, 2010
#14
  • Apr 9, 2010
  • #14
OOOOOHHHH NNNOOOOEEESSSS
It was the oil pump! Had the clickety clacks on the way home! Gonna have to pull the motor now....I did not want to experience a ford rebuild this early!
281pony
2,681
Oly, WA
Apr 9, 2010
#15
  • Apr 9, 2010
  • #15
sorry bro..
take my advice, put an oil pressure and water temp gauge in now. know your readings are accurate and shut her down immidiately. would have saved you a bottom end.
5.0W/5.0
129
Carson Valley, NV
Apr 9, 2010
#16
  • Apr 9, 2010
  • #16
there are two ways to look at it....One, I know have to put what I want in it, can strip it all the way down and start new. Two....DAMN FORDS!!!!
Not sure what direction I am going to go....Still have to tell the wife!
Cobra1741
152
#17
  • Apr 9, 2010
  • #17
Any ideas?
alot of times ive noticed that the when the oil pressure spikes its a good sign the oil pump might be going out. but if mine did it and i felt no difference in performance for a little bit, id be like ahh its just another cluster problem. i guess the only way to know with the foxes coolant and oil pressure is to get an aftermarket gauge! that sucks to hear it was the oil pump tho. and good luck with the woman of the house
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
  • dan50
  • Jul 18, 2026
dan50
