Oil Pressure
  • Thread starter Thread starter 91foxbod50
  • Start date Start date Jan 13, 2008
9
91foxbod50
486
  • Jan 13, 2008
The oil pressure in my fox is on the fritz. Most of the time its at the center mark, but at times its one bar higher. After i changed my power steering pump/pressure,return line my oil pressure was at the higher bar for a while.. But its starting to go back down again. Whats goin on ehh?
88mouse
630
Mooresville nc
Jan 13, 2008
  • Jan 13, 2008
Do you have a good connection on the sending unit?
Fast63
717
  • Jan 13, 2008
your oil pressure isn't on the fritz, your gauge or something else is. I think it is pretty typical of the stock gauges to change around like that. Mine ranges anywhere from below half to over the max mark. The only recommendation I know of is to get a new aftermarket gauge and hook it up if you want consistent readings, mechanical is usually better. Sorry :-\ Most important is that you in fact have oil pressure, so if it was me I would not even worry about it.
SuperStang83
1,693
Boyertown, Pa
Jan 14, 2008
  • Jan 14, 2008
Hook up a good guage and find out what is going on for sure. It makes all the difference in the world.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Jan 14, 2008
  • Jan 14, 2008
When you first start the car the oil pressure goes up until it heats up and thins out. Also stays up a little better for the first few weeks after an oil change.
What you really need is an AutoMeter gauge. Simple to install, and just about any of us can give you a run down on it. If you buy an electrical one holla at me.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Jan 15, 2008
  • Jan 15, 2008
Get yourself a proper gauge and check it. My factory gauge did the same thing. After installing an aftermarket piece I saw my oil pressure was just fine.
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
