  • SN95 4.6L Mustang Tech
oil pump 4.6
  • Thread starter Thread starter smoky
  • Start date Start date Mar 10, 2010
1 of 2 Next Last
smoky
29
  • Mar 10, 2010
any one do one is it bad
oxfordgt
288
Clarksville, TN
Mar 10, 2010
  • Mar 10, 2010
Say again in English please
smoky
29
  • Mar 10, 2010
need to put in a new oil pump is it hard to do
oxfordgt
288
Clarksville, TN
Mar 10, 2010
  • Mar 10, 2010
You have to remove all accessories, timing cover, timing chains, lift the engine a bit and drop the oil pan. But other then that it is pretty easy.
trinity_gt
3,125
81
99
Canada
Mar 11, 2010
  • Mar 11, 2010
What happened to the pump? How do you know it needs replacing? What are the symptoms?
Rickyll7
718
  • Mar 11, 2010
to put in new pump not hard
smoky
29
  • Mar 11, 2010
oil gauge go up to 20 then down 10 back up and if give it gas it go to 10 to 5 then sometime 20 all time
trinity_gt
3,125
81
99
Canada
Mar 11, 2010
  • Mar 11, 2010
Are you seeing these readings on a calibrated oil pressure gauge?
Is the engine making any noise? Knocking or tapping, for example?
The oil pump is a very simple and reliable device and is unlikely to fail unless you've hurt the rotor components with, say, underdrive pulleys... Low oil pressure readings can come from a number of sources, such as excessive oil clearances in the engines main or rod bearings (for example.) Even a bad oil pressure sender unit can cause goofy readings on the dash gauge (which is why I asked earlier if you were using a separate external gauge...)
bhuff30
6,037
35
129
Olathe KS
Mar 11, 2010
  • Mar 11, 2010
Please try to use correct grammar and sentence structure. It makes you look ignorant and stupid and makes me want to walk away from this thread without saying a word.
It is very unlikely that the oil pump is the problem. Oil pumps are constant volume pumps and generally work properly or don't work at all
What kind of gauge are you using and where is it tapped into? It is very possible you are just getting bad measurements.
If you determine that your oil pressure is ACTUALLY low, and not the result of a poor gauge setup, then your problem is most likely loose bearings or something related to oil escaping places it isn't suppose to. Again, it is VERY VERY rare for a pump to fail and provide low pressure. The low pressure is due to oil escaping at a high rate, like in loose bearings.
M
mode101
202
Dallas, TX
Mar 12, 2010
#10
  • Mar 12, 2010
  • #10
Are pulleys bad to put on these cars over time ?
trinity_gt
3,125
81
99
Canada
Mar 12, 2010
#11
  • Mar 12, 2010
  • #11
Some are because they fail to properly damp crankshaft torsional vibrations. In extreme cases, this can lead to breakage of the oil pump gears as the pump straddles the crank snout. If you go UDP, go Steeda as they actually made an effort to properly engineer not only the underdrive part but also the damper part of their design.
In the context of this thread though, a broken oil pump wouldn't produce any oil pressure. As bhuff said, oil pumps generally work or they don't.
It's possible that the pressure relief valve in the oil pump is acting oddly because of debris or burrs or something causing the plunger to stick partly open. The original poster needs to clearly state how he's measuring the pressure, if there are any engine noises attendant to these low oil pressure readings etc. It would suck to go to the trouble of opening and stripping the front of the engine, replacing the oil pump and re-assembling only to find the pressure doing the same thing because the problem is elsewhere (e.g. a bearing...)
smoky
29
#12
  • Mar 12, 2010
  • #12
ok it has a ar racing intake bbk throttle body 75mm paxton supercharger summit oil gauge engine is not making any noise at all no knocking or tapping just low pressure but some time it say at 20 pressure just dont know to put a new pump or engine it only has 20,000 miles on it
oxfordgt
288
Clarksville, TN
Mar 12, 2010
#13
  • Mar 12, 2010
  • #13
Check the oil pressure with a different gauge.
smoky
29
#14
  • Mar 12, 2010
  • #14
did that the same thing may i dont know
Rickyll7
718
#15
  • Mar 13, 2010
  • #15
run that wow hey what.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 13, 2010
#16
  • Mar 13, 2010
  • #16
my guess is a bad gauge
smoky
29
#17
  • Mar 14, 2010
  • #17
not 3 bad gauges copper line done the right way just 4.6 are sh--t
bhuff30
6,037
35
129
Olathe KS
Mar 14, 2010
#18
  • Mar 14, 2010
  • #18
You still don't know how to use complete sentences?
Try explaining where the gauge is tapped, how it was tapped, what kind of gauge, ect and maybe you can get some answers. The location makes a BIG difference.
The 4.6 is actually a very good engine and goes 3-400k miles in police and taxi service.
smoky
29
#19
  • Mar 14, 2010
  • #19
one is summit next cobalt used coper tubing put in were oil filter is were o.e.m was no luck in 4.6 my be taix or police car but for a mustang is a joke thank you for all the help but i,m done just going kill it 4.6 sh-t :Track::Track::Track:
Rickyll7
718
#20
  • Mar 14, 2010
  • #20
:Track:
:fairyfight:
:stirpot:
1 of 2 Next Last
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
J
2004 mustang 4.6 timing cover
  • jk66
  • Jun 26, 2026
SN95 4.6L Mustang Tech Jun 30, 2026
O
Resolved 2004 Mustang GT 4.6. No crank, no dash lights, No headlights or dome, No radio, no Hazards.
  • oldtimeracer
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2026
oldtimeracer
O
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
W
I have some 4.6 questions.
  • whiskerz
  • Nov 14, 2025
SN95 4.6L Mustang Tech Nov 25, 2025
squeak93
