  • SN95 4.6L Mustang Tech
p.i. heads
  • Thread starter Thread starter fast97gt
  • Start date Start date Aug 17, 2009
fast97gt
1,082
north carolina
Aug 17, 2009
  • Aug 17, 2009
what is the differenc in the remeo and the windsor head other then the bolt pattern for the valve cover.
TheSalad
372
Utah
Aug 18, 2009
  • Aug 18, 2009
Timing cover bolts are different. You will need windsor valve covers too. I would try and get 01+ (romeo) heads if possible.
trinity_gt
3,125
81
99
Canada
Aug 18, 2009
  • Aug 18, 2009
In addition to the timing cover bolts and valve covers, Windors use different cam caps (individual versus the Romeo "ladder" style...) and, IIRC, the cams use press-on gears versus the bolted Romeos.
fast97gt
1,082
north carolina
Aug 18, 2009
  • Aug 18, 2009
well i got a set of p.i. heads (windsor) off my 2000 that dropped a valve, but any way i found a pass. side head to replace it but i think its a romeo. my head can be fixed but wanted to weigh my options. how can i tell the difference, oh and if its a windsor ill be stoked cause they only want 30 bucks for it, but needs a valve job
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
W
I have some 4.6 questions.
  • whiskerz
  • Nov 14, 2025
SN95 4.6L Mustang Tech Nov 25, 2025
squeak93
speedmaster new 302 block?
  • rednotch
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2026
rednotch
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
