  • SN95 4.6L Mustang Tech
P.I. Swappers
  • Thread starter Thread starter onlyme
  • Start date Start date Apr 15, 2005
onlyme
375
missouri
Apr 15, 2005
  • Apr 15, 2005
I was just wondering all those that have done the p.i swap what cams are you using and what kinda hp numbers are you making? whats the best cams for stock p.i heads with good gains?
stimmler
248
Japan
Apr 15, 2005
  • Apr 15, 2005
anything is better but go with as much lift as possible and a shorter duration without ported heads. Plus if the duration is too long you will get piston to valve contact. Mine are custom from fox lake. I got 286 hp on a mustang dyno which typically get less hp than a dynojet. In comparison a new stock 2005 gt got 250-260 on the same dyno
CanadaStang
2,093
Mb
Apr 15, 2005
  • Apr 15, 2005
Vt stage 1's are good or the stage 2's if you want more HP, but you should change the springs if you go with the stage 2's
onlyme
375
missouri
Apr 16, 2005
  • Apr 16, 2005
thanks
thanks i was curious about that
W
I have some 4.6 questions.
  • whiskerz
  • Nov 14, 2025
SN95 4.6L Mustang Tech Nov 25, 2025
squeak93
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
