i just bought a ABC cobra R hood i cant afford to get it painted right now after spending the money on the hood, so i was just going to paint it semi-flat black for now, but im not sure on how to prep fiberglass, :SNSign:
wait and paint it. dont be like a ricer!!
assuming it has jelcoat, sand it with 400 grit to 600 grit sandpaper. Do not sand through-you just need to create scratches for adhesion. Once it's dull, it's good enough to paint.
I painted mine (2 weeks before it was totalled).
It came out well, only a couple minor imperfections that only I could notice. Mine was a color change though, so there was a lot of prep work as the previous owner had thick stripes on it with even thicker pin striping. I spent about 4 weeks, a couple hours each night, doing the prep work. (Painting is really 90% prep)
I used my lil 15 gallon compressor and a HVLP gun. I did all the primer will rattle cans, but laid down the color and clear with the gun.
I built an 10X10X8 spray booth with PVC, plastic drop cloth, duct tape (of course!) and a couple of (HVAC) air filters - totalled about $40 bucks. I used a couple fans I have in the garage, one on each end of the spray booth, one pushing air in (thru the filter) and the other fan at the other end pulling air out thru the air filter. It worked very well.
i acutally just talked to a friend of a friend, that has his own shop, and does a ton of body work. ive seen his work its rely good.. for 100$ he will prep, paint and clear it, it will be there on saterday morning
Yep, you can always repaint!wow that looks good, i can paint out of a rattle can good, i might have to try , if it looks like s**t, i just sand it off
That's an awesome deal. $100 barely will cover the materials.
OoOoO... shiny. are you telling me those struts were perfectly okay? wow thats amazing! WHere you okay.
98cobra281 i heard you were gettin you hood today. is that from the the shop?
