I sent my car into the mechanic today, and gave him these instructions:
1. Order and install a 130-amp alt.
2. Grind alt. bracket to make it fit.
3. Upgrade to 4 gauge wiring.
When I got off work, he did none of the above. Instead, he installed a refurbed alt, that supposedly puts out 78 amps. Here's what he told me in a condensed version:
"Yeah, I know you've talked to people on the Internet, but not all of them know what they are doing and it's not safe. For starters, I tried to order a Special Service Mustang alternator, but Ford doesn't sell them anymore (apparently he didn't realize other companies made 3G alts). Secondly, it won't fit, and even if I grind the bracket, it won't be secure anymore with the modified bracket you risk it flying loose into say, your radiator because of a higher chance of it breaking off. Thirdly, I don't want to change your wiring because there's a risk of burning your wires. I'm doing all of this for your safety, and the fact that I'm a licensed mechanic and I don't want to lose my license."
He then proceded to hook up the battery to an meter and showed me how the voltage dropped at low idle. So he told me not to idle a lot. He also strongly recommended me to remove my underdrive pulley, but says it is not necessary.
Consultation with Ford dealership mechanics turned out almost the same result, with the exception of a few who said it could be done.
Well, I've got a new alt. in my car, even though I didn't specifically ask for that one. I don't know if I should be happy or not, as I don't think this refurb will really handle the car audio and headlights. Mind you, it's just a hi-output CD player, but I plan on adding amplifiers to the speakers (no subs, it's a vert) so that may hurt it even more. I'm some what miffed at both the fact that he said he couldn't do it, and even more at the fact he installed the new one without consulting me. What do you guys think of the situation?
