Passanger Side Window Not Right
fswd
Hello everyone. I have a question about my passanger's side window on my 99 mustang gt convertible. It seems that the window is angled outward so when you close the door the window is caught on the soft top and doesn't close all the way. Let me explain. The window isn't angled in toward the inside of the vehicle enough for it to clear the edge of the top. When i close the door with the window all the way up it just slightly hits the top and catches which catches it and makes it stick outside of the top whicle the door is closed making about a half and inch gap at the top of the window. if I push in the top of the window while I am closing it, it will close all the way because the window is angled enough in to clear the top. When i angle it in the also makes it go down a little because of the way it is pointing in already. This is a difficult question to explain in words but I hope I did it justice. What I am wondering is if I take off the inside door panel are there screws to adjust the angles of the window from inside the door? Is there any other way to attack this problem? Thank you for your help.
Thanks,
Dan
