  • SN95 4.6L Mustang Tech
PI cam/intake shift points
  • Thread starter Thread starter darkstar2002
  • Start date Start date Aug 11, 2008
D
darkstar2002
  • Aug 11, 2008
I just did a PI cam/intake swap and was wondering what might be the best shift points. I have a 97 auto with 3.27's
Mustang5L5
Mod Dude
Feb 18, 2001
43,361
18,107
224
Massachusetts
Aug 11, 2008
  • Aug 11, 2008
5500ish
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Aug 11, 2008
  • Aug 11, 2008
my max power (225) is at 5000rpms..... and you always want to shift a little above your power......
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 11, 2008
  • Aug 11, 2008
A little trial and error would figure it out. My Comp 262's peak is about 4800. I shift at about 5300.
CobraRed_96_GT
1,421
UCSD/La Jolla
Aug 11, 2008
  • Aug 11, 2008
4800 is really low, even with NPI heads. Stock PI cams on PI heads peak at 5250, i'd think stage 1 cams would at least push it there.
bhuff30
6,037
35
129
Olathe KS
Aug 12, 2008
  • Aug 12, 2008
The ideal shift is actually different between every gear change. For example, the jump from 1st to 2nd is pretty big compared to the jump from 3rd to 4th, so you'd want to run 1st out further. This can be calculated by getting your car dynoed and then graphing rear wheel torque vs wheel speed for every gear and looking at the point at which the lines cross. The ideal shifts for a stock NPI would look something like this:
1-2 5500
2-3 5250
3-4 5000
4-5 5300 (because of the much deeper OD gear)
I generally shift at 5k because my syncros aren't happy above that. It occasionally tends to grind on higher rpm power shifts.
Nope, this post doesn't answer your question about where to shift at all. But you could probably shift these rpms up by 200 and have a good idea. You really just have to get to the track or dyno to figure it out for your specific car.
LI98GTStang
1,715
L.I., NY
Aug 12, 2008
  • Aug 12, 2008
With PI cams and intake on NPI heads, I did my best times at the track by shifting at ~5500rpm from 1st to 2nd, then ~5300rpm 2-3, 3-4 on a 5speed.
T
TGJ
1,049
  • Aug 13, 2008
When I did this swap a long time ago in my 96 TBird, Modular Depot had the 1-2 shift @ 6500 RPM, the 2-3 @ 6200 RPM. Worked really good for me, 14.1 @ 95 MPH in a car that is a good 600 - 800 pounds heavier than a Mustang GT. My mods at the time were:
Removed Air Silencer, SVO 70mm TB, P&P stock upper intake, PI Intake, PI cams, Steeda UD Pullies, Mustang GT TC, Custom cat back exhaust, 3.73 TL Differential on hoosier 26" Drag radials.
Wasn't a hell of a lot done to it.
I don't recommend WOT shifts into OD or downshifts from OD to 2nd. <-Not a typo...
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 13, 2008
  • Aug 13, 2008
I based my shift points on my dyno graph. Peak HP was at 4850. Still it was 500RPMs higher than the NPI cams
98COBRA281
1,348
30
59
Aug 13, 2008
#10
  • Aug 13, 2008
  • #10
my peak hp was 5k, with pi cams......
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 13, 2008
#11
  • Aug 13, 2008
  • #11
My peak HP is higher than yours.
98COBRA281
1,348
30
59
Aug 13, 2008
#12
  • Aug 13, 2008
  • #12
not for long
D
darkstar2002
#13
  • Aug 14, 2008
  • #13
Well thanks for all your input. I will hopefully be able to try some more stuff out fri night at the track if the weather holds out. There forecasting rain.
J
justinschmidt1
349
#14
  • Aug 15, 2008
  • #14
Ive always shifted my auto at like 5800-6000 cause it drops down so much from gear to gear.
Seems to me that you need to wind the auto out more than a 5 speed to keep in the powerband.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Valve hitting piston?
  • krazedstang
  • Jun 9, 2025
SN95 4.6L Mustang Tech Jun 12, 2025
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
