Picked up an 85gt, need help with year of motor in car/firing order
Rynb15
132
Hello, I picked up a 1985 gt project car. Lots of stuff to put back together on this car.But car is staright, not rusty and has a decent interior. Car has a f150 bottom end installed with the 85 mustangs top end. (previous owner did this)The number i got off the block by the starter is 5f30. This is the only number I could find on the block. So would this be a 95? And I read the 94 and up truck 302s have the Ho/351 Firing order.(motor currently has standard 302 firing order)Car has never been driving with his motor installed. Just started up. Car has sat for years after this swap. Motor starts up and idles decent, im going to rebuild the carb and make sure timing is set right. But want to make sure i have the correct firing order. Thanks guys.
  • Sponsors(?)
General karthief
Mod Dude
Aug 25, 2016
14,613
4,626
193
polk county florida
I would pull the valve covers, crank the engine by hand (I have really strong hands, you may use a big socket/cheater bar) to tdc, verify #1 cylinder, then turn the engine over slowly and note valve movement indicating next cylinder that fires, there are only two firing orders so not too hard to figure out, and thats a good thing cause sometimes I not too smart.
a real mechanic may have a better way, I'm a fake mechanic.
Reactions: Rynb15
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,187
2,709
224
74
Dublin GA
lowendmac.com
This doesn’t prove that the block is a HO block. Some trucks evidently use a HO firing order with a low lift cam (this will result in less than the desired HP output). However, it will definitely prove that a block can’t be HO because the firing order is wrong.
Remove the #1 & #3 spark plugs. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Slowly turn the engine until the TDC mark and the timing pointer line up. Mark TDC on the balancer with chalk or paint. Put your finger in #3 spark plug hole and crank the engine 90 degrees. You should feel pressure trying to blow past your finger. If you do not feel pressure, repeat the process again. If you feel pressure, it is a HO engine.
No pressure the second time, remove spark plug #5. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Put your finger in #5 spark plug hole and crank the engine 90 degrees. If you feel pressure now, the engine is not a HO model, no matter what it says on the engine.
Using a small carpenter or machinist square to mark the harmonic balancer off into 90 degree sections may be helpful here.
A 15/16 deep socket & breaker bar or ratchet may be used to turn the engine.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
Do an end to the injector wring test to make sure that the injectors are properly sequenced for a HO engine and computer
Disconnect the main connector from the computer and pull it down so that you have good access to the computer side of the connector.
Place one voltmeter lead in pin 40 or 60 - they are both the main computer power ground. This lead does not change for any of the tests
Disconnect all the injector connectors from the injectors.
You will re-connect them one at a time to do the testing. Once you have checked an injector lead, disconnect it before testing the next injector. Fail to do this and you will get incorrect results
Turn the ignition switch to Run
Check pins 37 & 57; you should see 12 volts.
Computer wiring harness connector, wire side
Computer wiring harness connector, computer side
Here are the HO injector wires that are different; check to see that you have 12 volts on them one at a time.
Connect injector #3, look for 12 volts on pin 12 on the computer. Disconnect the injector connector from the injector before testing the next wire.
Connect injector #7, look for 12 volts on pin 42 on the computer. Disconnect the injector connector from the injector before testing the next wire.
Connect injector #5, look for 12 volts on pin 14 on the computer. Disconnect the injector connector from the injector before testing the next wire.
Connect injector #4. look for 12 volts on pin 13 on the computer. You are finished now and can reconnect all the injector connectors to the injectors.
