Actually you may want to go back and set that back dot to dot...a lot of new cam designs are setup with 4* on purpose.
I called TFS way back when I first got my TFS1 cam and they 100% recomended running it dot to dot. I later saw several posts about this on Hardcore and even found it mentioned in one of the articles I had when I researched cams for my combo.
IIRC even FTI's custom cams have some degree of this depending on needs.
Stock springs FTL...get new ones. Call the cam maker and ask questions about seat press. and stuff to make sure you springs are the best possible fit. Lift is only part of the EQ. You have seat pres., open pres., ramp rate, lift to look at. Most springs in the .550 should be good but better safe than sorry since its just a phonecall to the info.
If your getting any machine work done to the heads to freshen them up ask the mech. shop. I did and said "I am thinking about going to 1.7rr at some point and the cam specs are for 1.6. So that is why I am looking for something safe to .550 if that effects the seat pres. stuff that is why I am telling you".
