  • 1994 - 1995 Specific Tech
Pinging at full throttle ??????
  • Thread starter Thread starter Igofaster13
  • Start date Start date Jun 19, 2006
Igofaster13
170
San Diego
Jun 19, 2006
  • Jun 19, 2006
My girls car is a 95 gt, it pings at full throttle, it is stock, but has a kn and flows. What could be wrong with it. Thanks
RIO5.0
6,892
N.H.
Jun 19, 2006
  • Jun 19, 2006
Use the search feature and you'll find a nights reading on this very subject...It can be a mofo to chase down and its inherent to the 95...
It can run the gammit on parts and variables that contribute to pinging....
I for one had a pinger and never did get it to swap til it swapped heads...Can't make it ping now..
I would suggest reading up some and make a decision on what direction to start...
I would make sure the state of tune is decent and being conservative (10 deg) or less will usually make it more livable...From there it can run into various sensors that some have changed and made it clear up...
Good luck and start reading...Seems like no easy answer on this one...
bill302
2,131
alabama,gadsden
Jun 19, 2006
  • Jun 19, 2006
check the timing and repost results....if timing is in spec....10-12 degrees btdc..you might need to run seafoam through the intake to clean any carbon build up.also if this is just a one time occurence could be bad gas...running higher octane should clear up pinging but it should run fine without pinging with 97 octane...then again it might need a good tune up....these are good places to start but it could be 1 of 1000 things....
Swarzkopf
973
Pittsburgh
Jun 19, 2006
  • Jun 19, 2006
Have you ever messed with the cars timing? If not, it's probably the MAF. Quite honestly, even never seeing the car, I'd put down $20 that it's the MAF right now.
My own car and so many other 94-95 GT's I've come across have had the exact same issue.
When the MAF gets dirty or goes bad on our cars, seems the first symptom will be a lean condition at load or WOT. As the MAF gets worse, it alternates between pig rich and very lean (causing bad drivability).
Did the pinging start/get worse after you installed the K&N? Lots of time out of the box K&N filters have too damn much oil for our MAF to like- the oil gets on the MAF and it's all downhill from there.
I'd first try cleaning the MAF. Compressed air is what I trust...if it's real bad, alcohol on a q-tip seems to work too and others have used brake cleaner. If that doesn't clear it up, try swapping the MAF from another car on to see if it still pings. If it goes away, you need a new MAF.
Good advice (even though in this care I betcha it's the MAF). My 93 LX 4-banger was pinging like mother****er...with 140K miles on the clock I figured the carbon buildup was pretty bad. The smoke show from the SeaFoam was very impressive. It hasn't pinged once since (on 87 to boot).
HISSIN50
34
129
Jun 19, 2006
  • Jun 19, 2006
I'm sure someone mentioned it - but check FP at WOT. It's funny that you only get the pinging there (when demand is greatest) and not during other times. I'd be checking for a weak pump initially. How long as the fuel filter been on there?
Good luck.
gcomfx.com
3,690
Republic, MO
Jun 20, 2006
  • Jun 20, 2006
I had the ping..... Was scared to put nitrous on the car. Dropped the timing, put in Autolite 24s (colder than stock and only $1 each at wally world). What made the biggest difference was making the gap on the plugs closer. I run .035 for the juice. I don't have a ping now unless I'm spraying 125 shot and my timing is too high.
Definately, Check your timing. If it's out of whack, try to reset it. If it doesn't stay, I would look at the dampener, it could have slipped or is getting old and wobbly. Also if your timing is jumping around your dizzy could be going out.
illwood
636
Worcester, MA
Jun 20, 2006
  • Jun 20, 2006
Another thing to check is oil getting in the plenum from the EGR line.
Igofaster13
170
San Diego
Jun 20, 2006
  • Jun 20, 2006
So I should change out the mass air flow sensor? I have not messed with the timing and I dont think anybody has ever messed with the timing.
Swarzkopf
973
Pittsburgh
Jun 20, 2006
  • Jun 20, 2006
I wouldn't say rush out and buy a new one right away...try cleaning yours first. If that fixes the problem, great. If not, swap a new one on. If that fixes it, great, if not, return it. At that point if it's still pinging you have ruled out the MAF...but I still think that the MAF (either cleaning yours or buying a new one) will fix your pinging.
Good luck, let us know!
bill302
2,131
alabama,gadsden
Jun 20, 2006
#10
  • Jun 20, 2006
  • #10
heres a link that demostrates how to clean the maf sensor...
http://www.muscularmustangs.com/maf.php
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jun 20, 2006
#11
  • Jun 20, 2006
  • #11
yeah all you need to do is clean the maf, it shouldn't be bad just because it got oil on it. Just can't read accurately.
The maf/iat/ect are the main sensors that read when you are at WOT. Clean both the maf/iat and RESET THE COMPUTER. You have to reset the KAM after you clean a sensor so the computer can relearn the new sensor and start with a new adaptive strategy.
If it doesn't ping at part throttle, the O2's are likely still ok.
Scott
Igofaster13
170
San Diego
Jun 20, 2006
#12
  • Jun 20, 2006
  • #12
I Cleaned the maf with electronics cleaner and the ping is gone ! Thanks everybody.
Swarzkopf
973
Pittsburgh
Jun 20, 2006
#13
  • Jun 20, 2006
  • #13
Good to hear!
reddy351
560
12
38
Columbus, Ohio
Jun 20, 2006
#14
  • Jun 20, 2006
  • #14
Did cleaning the MAF make the car feel any faster? I'm just curious because I would assume that now it's getting the proper fuel load, it should be. I have the same problem but I can't seem to find my "T-20 Security" bit.
Igofaster13
170
San Diego
Jun 20, 2006
#15
  • Jun 20, 2006
  • #15
Ya the car seems a little faster and the idle is a little smoother. I reset the computer too by the way.
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Jun 20, 2006
#16
  • Jun 20, 2006
  • #16
I have the same problem, exactly. Full throttle only, but not untill I'm going like 55+.
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
